@Group("Model",0) @Order(1) attr Model_file = "my.obj" @Group("Model",0) @Order(2) @Range("Scale to Parcel Size","Scale to Parcel and Set Height","Set Height","Do not scale (model in realworld dimensions)") attr Model_Size = "Scale to Parcel and Set Height" @Group("Model",0) @Order(3) attr Model_Height = 50 Group("Model",0) @Order(4) @Range("0","90","180","270") attr Model_Rotation = 0 @Group("Lot Attributes",1) attr distanceStreet = 0 // Lot setback @Hidden attr Block_Area = 0 Block --> set(Block_Area,geometry.area) //PM: We have to store this value to calculate the FAR below report("Block Area",Block_Area) //PM: Plus we write it out for the report offset(distanceStreet) comp(f) {inside: alignScopeToAxes InsertModel | border: O} InsertModel --> // examples of different insert 'modes' case Model_Size == "Scale to Parcel Size": i(Model_file) // the insert operation fits in the model automatically and scales the height accordingly r(scopeCenter, 0, Model_Rotation, 0) Mass case Model_Size == "Scale to Parcel and Set Height": s('1,Model_Height,'1) i(Model_file) r(scopeCenter, 0, Model_Rotation, 0) Mass case Model_Size == "Set Target Height": s(0,Model_Height,0) center(xz) // in case only height is set.. i(Model_file) // ..the insert operation scales the width and depth according to the given height r(scopeCenter, 0, Model_Rotation, 0) Mass else: s(0,0,0) center(xyz) // in case size is 0.. r(scopeCenter, 0, Model_Rotation, 0) i(Model_file) // ..the insert operation uses the realworld dimensions Mass ############################################## # REST IS THE SAME AS IN THE PREVIOUS CGA FILE # @Group("Land Use Control",5) @Order(1) @Range("Residential","Commercial","Mixed-Use","Industrial", "Retail","Government","Cultural","Education","Hotel") //PM: @Range annotation creates drop-down attr Land_Use = 10%: "Residential" 50%: "Commercial" 30%: "Mixed-Use" else: "Industrial" //PM: These attribute is usually controlled by image map @Group("Building Attributes") @Order(2) attr retailheight = 5 @Group("Building Attributes") @Order(1) attr floorheight = 4 @Group("Visualization") @Range("Mass_white","Mass_color","Floors","MassAndFloors") attr vizMode = "MassAndFloors" @Group("Land Use Control") @Order(5) @Description("% of commercial floors in a mixed-use residential building") attr mixedUsePercentage = 0.4 //PM: New attribute @Group("Building Attributes") attr getNumberOfRetailFloors = case Land_Use == "Residential" : 0 case Land_Use == "Industrial" : 0 case Land_Use == "Education" : 0 case Land_Use == "Cultural" : 0 case Land_Use == "Commercial" : 1 case Land_Use == "Mixed-Use" : 1 else : floor(rand(1)) getColor(myLandUse) = case myLandUse == "Commercial" : "#DD7300" case myLandUse == "Retail" : "#D63200" case myLandUse == "Residential" : "#FFD255" case myLandUse == "Industrial" : "#720000" case myLandUse == "Government" : "#1887B2" case myLandUse == "Cultural" : "#46B8E6" case myLandUse == "Education" : "#8D7CC1" case myLandUse == "Hotel" : "#D8ABC8" else : "#888888" calcNumberOfFloors = rint(scope.sy/floorheight) //PM: handles mixed use and adds retail floors Mass --> case Land_Use == "Mixed-Use": split(y){ retailheight * getNumberOfRetailFloors: Floors("Retail") | floorheight * mixedUsePercentage*calcNumberOfFloors : Floors("Commercial") | ~1: Floors("Residential") } MassViz(Land_Use) else: split(y){ retailheight * getNumberOfRetailFloors: Floors("Retail") | ~1: Floors(Land_Use) } MassViz(Land_Use) // PM: sets the color according the landuse-parameter and splits them in single floors using a repeat split Floors(myLandUse) --> color(getColor(myLandUse)) split(y){ ~floorheight: comp(f){ bottom: FloorArea(myLandUse) } }* FloorArea(myLandUse) --> reverseNormals report("GFA."+myLandUse,geometry.area) //PM: the default staticts show the sum, so we just have to call it for each floor report("FAR",geometry.area/Block_Area) //PM: same here (we just do the division for each floor instead for the whole sum at the end) FloorViz(myLandUse) O --> color("#A7BC2B") ############################################## # Visualization # MassViz(myLandUse) --> //DOS: the idea is to have viz modes similar to those in the reporting tutorial case vizMode == "Mass_white" : Mass. //DOS: solid white mass case vizMode == "Mass_color" : //DOS: mass colored by land use color(getColor(myLandUse)) Mass. case vizMode == "MassAndFloors" : //DOS: transparent mass with floors set(material.color.a, 0.2) Mass. else: NIL //DOS: if set to "Floors" there should be no mass shown at all, only floors FloorViz(myLandUse) --> case vizMode == "Mass_white" || vizMode == "Mass_color" : NIL else: color(getColor(myLandUse)) Floors.
