Shapfile is too far for model
2453
08-25-2014 12:16 PM
guilhermetsig
Good afternoon guys
I'm having problems with my terrain.The shapfile is too far from model.Boths are in the same datum(SIRGAS2000).
CityEngine shows a message  "the data is located too far from the current scene's contents.Either edit the (geo-)location of the data, choose an adequate projection, or import it into a new empty CityEngine scene".
I need help please
DavidWasserman
Does your shapefile have a .prj file associated with it? Can you import it into a an empty CE scene?
David Wasserman, AICP
MelitaKennedy
Esri Notable Contributor
My guess is that it's in a projected coordinate system when the model is using a geographic CS or vice versa. Take a look at the extents of the data sources versus their coordinate systems.
Also see this thread that mentions issues with comma-as-decimal-delimiter.
Melita
