Shapes not generating
7068
11
05-29-2013 08:52 PM
JoanneO_Brien
I've just created a new scene, and imported a geodatabase containing all the layers I'm interested in. I've then imported an obj model from sketchup no worries. But when I try to assign a rule to one of my building footprints it seems to assign, but nothing appears when I generate it. I've checked all the usual stuff such as the show/hide shapes and models etc but none of that seems to be affecting it. I successfully use this same rulefile on the same parcel in other scene's (and checked that they're still working). I also tried to create a whole new scene to see if there was a bug in my scene but to no avail...any suggestions please?
Secondly I tried to export the same model from above from a different scene as an obj and import it into this scene, but once it's imported I can't seem to move it, it seems static. Is this normal?
On a different note I was wondering if there was a way to create a shape parcel between my roads but excluding my building footprints so that I don't have issues with two shapes on top of each other? Would be useful for creating gardens etc...
I've attached a picture which I hope will help you understand the scene I'm working with.
JoanneO_Brien
Hi Matt
unfortunately I haven't been able to re-create this issue systematically. I can reproduce it accidently plenty of times, but for example I can apply a rule to a new parcel, and get the error, then delete the rule and re apply if to the same parcel, it applys fine half the time, and the other half it causes my model to go crazy...
I just got the same error today when I was modifying a rule by changing an attr to a const. In this case I hadn't saved before re-generating the model which again makes me think that saving the rule is linked to it in some way but not necessarily the whole issue.
I generally get this issue happening at least twice a day for various reasons...
I'll let you know if I come up with anything else.
Regards
Joanne
MatthiasBuehler1
hmm. tricky.
if you have the issue when you see that only a small thing has changed ( e.g. const to attr ), can you save the rule and maybe undo the change to see if you can reproduce the issue ?
without reproducing this properly, it's hard to track down..
let me know if you find something. seems you have a 'workaround' currently..
matt
