Problem export to ESRI Geodatabase from City Engine Project
2131
08-07-2014 05:30 AM
Amirimohammed
hello :
i tried to export my work from city engine to gbd, when i want to open it in arcscene i had this error message
I joined here the two error message , and the scene of my work in city engine
THANKS
MatthiasBuehler
Di you get the same error when you only e.g. export 1 of these buildings and try to open in ArcScene ?
If so, can you track down which building causes this issue ? That would make things clearer.
Let me know ..
Matt
Amirimohammed
Hi Mathias Buehler
thank you for you answer.
in the last week, i tried all possibilities ( export every layer alone, every building,export in other format like KMZ, COLLDA, AUTOCAD and OBJ ) and everytime i had the same error, but when i tried with a other projet the export worked.
i'm sure that there are something wrong in my projet i could't know it
regards
AMIRI
MatthiasBuehler
hmm. ok.
then try to migrate all to a new project ..
good luck !
matt
