Polygons seems separate on web scene but that are snapping each other in project file
2058
12-18-2013 10:34 PM
by Anonymous User
Not applicable
Original User: gsenyurdusev
[ATTACH=CONFIG]30000[/ATTACH][ATTACH=CONFIG]30001[/ATTACH]
The polygons that belongs to buildings are not separate (All vertex points are snapping each other) but sharing web scene this project, building's polygons seems separate.
Why this is happening? and how can I solve this problem?
You can checkup this web scene;
http://www.arcgis.com/apps/CEWebViewer/viewer.html?3dWebScene=18d3fba2249c4a6291e9181658313dfc
by Anonymous User
Not applicable
Original User: matthiasbuehler
Does this also happen if you only export 1 building alone ?
What export settings are you using ? Can you post a screenshot of the export settings ?
Let me know ..
matt
by Anonymous User
Not applicable
I have experienced a similar situation with gaps appearing between polygons on exported web scenes, as shown in the image below.
[ATTACH=CONFIG]30287[/ATTACH]
I have attached a zip file of a CityEngine 2013 project that demonstrates the issue. When the generated models are exported to a web scene, gaps that weren't visible in CityEngine appear between the polygons.
Michael
by Anonymous User
Not applicable
Yes, that's now a known issue. There's some 'shifting' going on, clearly a bug.
It's on the bug list. Sorry I can't do anything for you for this right now. 😞
Thanks for reporting !
matt
GucluSen
matt
I hope it is fixed as soon as possible.
