Hello,
I'm working on tutorial 13 (Facade Wizard). But when i open a .jpg in the facade wizard window, I'm not able to see the image and work on the facade elements. Instead of an image I came across with a black image.
I've attached how it looks like. I tried it in different scenes with different .jpg or tiff but it's not working.
Thanks for any advice.
that such friends, I am proving the CityEngine to see if it is feasible to buy it, because we are already buying Artificial 3D Analyst to develop 3D Cadastre of my country and work with sketchup, however we are interested in the CityEngine analisar porder, I'm with the trial version and one example shows how to export through ArcToolbox tools called CityEngine_Prep, ArcMap project to CityEngine, where I find him to be tested. help thanks.[ATTACH=CONFIG]23401[/ATTACH]
Hi ..I got some feedback :The toolbox relies on the Data Interoperability extension from Safe software.Do you have that installed?Matt
Hi !The data is in part 3 (not 1000% sure though) .. This is a little odd, but download all parts, then you get all data for sure.Cheers !M.
Hi !In the CityEngine.ini file which you find in the program's directory, edit the line-Xmx2048Mto a bigger value .. e.g.-Xmx4096M ( does not have to be a power of 2 value )This will increase the RAM amount which is reserved for the Java side of CityEngine. Note this RAM is locked for CE only and cannot be accessed by other applications or OS. This is a Java thing. So play with this very carefully.Cheers !Matt
Signed in members can post, follow updates, and more. New here? Register a free account.
