Is there any way to get the value of an attribute in the inspedtor to change when you use the set operation in your CGA code?
3061
12-04-2015 10:19 AM
LoringTupper
I'd like the set operation to not just change the value of an attribute but also change the value that is displayed in the inspector, is this possible?
attn. X = 1       The value of X in the inspector is 1
In the code I have the following line:
set(X,2)             The value of X in the inspector still is 1, how do I get it to display the current value set in the code?
Tags (1)
