Is there a way to find out which shape/polygon uses a rule?
3486
07-24-2015 03:44 AM
LR
I can right-click on a building in the viewport and select other objects which use the same rule file as it. Is there any way to do this using a rule file? Basically, I want to select a rule and see where (or if!) it’s been assigned.
Right now I’m checking this by giving the rule a large extrusion so it’s easy to spot corresponding objects visually in the viewport, but I wonder if there’s a better way.
by Anonymous User
Not applicable
Sorry, there is not a built in function for that. Try this:
Draw a temporary shape. Place the rule on the shape. Right click on shape the pick "select all with same rule".
Delete temp shape when done.
Chris
by Anonymous User
Not applicable
Chris
LR
I guess that's the best currently available solution for the problem. Thanks.
