How to set rule / make sure it exists
1980
02-25-2016 08:47 PM
ChristianShiel1
When I am run the prt4cmd tool I get the error: OBJEncoder::encode failed, exception caught 'unknown rule'.
Now I have this rule file in the same directory and its not picking up for some reason.
It something to do with this part of the call: ruleFile:string=bin/candler.01.cgb
ChristianShiel1
I fixed this error by starting again and this time added absolute paths instead of relative when pointing to rule files. That fixed it!
AbhishekRathi1
Dear Christian,
Kindly refer the links below and try to follow. Hope it will solve your purpose.
esri-cityengine-sdk/examples/prt4cmd at master · Esri/esri-cityengine-sdk · GitHub
esri-cityengine-sdk/prt4cmd.cpp at master · Esri/esri-cityengine-sdk · GitHub
https://media.readthedocs.org/pdf/turbogears/latest/turbogears.pdf
The PDF will help you to configure and work properly.
Thanks and Regards
Abhishek Rathi
ChristianShiel1
