How can I project images to coordinate with the OSM data that I downloaded?
1590
08-07-2019 01:58 AM
大头熊
Here is the thing:
I've downloaded the OSM data and import it into my city engine scene then reprojected the image in Arcmap as WGS1984 UTM Zone 48N(the same as OSM data),but I still cannot get them coordinate,like the image I upload displaying.
So who can help me? Or tell me the right process that I can download the right projected satellite imagery OSM data can coordinate?
Thanks!
Luiz_AmadeuCoutinho
Look like the image is not georeferenced. Did you use the Georeferencing Toolbar? Georeferencing toolbar tools—Help | ArcGIS for Desktop  or only apply reprojection?
大头熊
Thanks for your reply, and,  I've tried to use the Georeferencing Tool at the Arcmap to match the image with the OSMdata(that I converted to .shp), but
大头熊
But I don't think it works correctly...So the image I uploaded is the one that I just apply reprojection.
Thanks again~
MelitaKennedy
Esri Notable Contributor
When you reprojected the image, what tool did you use? The Define Projection Tool or the Project Raster tool?
I would expect OSM data to be in either 4326 / WGS84 or 3857 / Web Mercator (also known as WGS 1984 Web Mercator Auxiliary Sphere in ArcGIS), not in 32648 / WGS84 UTM 48N.
Melita
