GDB import - doesn't see 1 feature class
5109
7
07-26-2013 12:22 AM
by Anonymous User
Not applicable
Original User: varvara_t
When importing features from File GDB, I can't see one point feature class - all the others are OK (including other points).
What could be the reason?
When I export it to SHP - it's OK loading it in CE.
Also, is there any way to import lines not as streets (not divided into segments and nodes)?
I try building metro scheme (like the one created for LA), and I don't need 300 objects instead of 15...
MatthiasBuehler1
hi,
can you share the file ? can you PM me your mail address ?
lines are always interpreted as streets in CE. try playing with the subdivision settings of both segments and nodes.
let me know..
matt
by Anonymous User
Not applicable
Hi Matt,
The file is enclosed (archive contains GDB with this unreadable point feature class), I sent you my e-mail via PM.
I was almost about the lines - but still had some hope )
Thank you very much for all!
by Anonymous User
Not applicable
Original User: matthiasbuehler
Thx for the files and the PM.
That feature class seems to be in a custom projection. That's not supported.
We recommend usually to use a default UTM projection.
[ATTACH=CONFIG]26338[/ATTACH]
Otherwise, what may cause an issue is the kyrillic characters. But let me know if this already solves the issue.
Matt
by Anonymous User
Not applicable
I really seemed to miss it was in the wrong projection �?? but unfortunately it didn't have any effect, it's still impossible to import it to CityEngine.
I also tried deleting any Cyrillic fields, I even deleted all the attributes �?? the result was the same�?�
For SHP everything is OK again.
MatthiasBuehler1
I've been able to import the points, so no worries there.
The shapes are true circles, so no polygonal shapes. I'm not perfectly sure, but I guess that's not supported yet. Try converting the circles to polygonal shape features, ok ?
Matt
by Anonymous User
Not applicable
Matt, you are genius!!!
Thank you - it worked, the problem was caused by using circles. I think I never would have guessed )
Now everything is OK, including export from ArcScene to 3WS (I also had errors reported because of this feature class).
by Anonymous User
Not applicable
hi,
thanks for the kind words. glad it works for you !
cheers !
matt
