fileSearch & fileRandom Limitations
1788
03-15-2021 12:28 PM
DevinLavigne
I discovered today that fileSearch and fileRandom will not return a result if there is a space in the path.
For example print(fileRandom(/Project Name/*.*)) will not work but print(fileRandom(/DifferentProjectName/*.*)) does. I renamed my project but it broke a ton of references in other places. Is there a way to get around this limitation?   or chr(32)...something like that?
DavidWasserman
It is incredible how much of rule design is just filename management.
David Wasserman, AICP
CherylLau
This is actually not a bug.  Whitespace inside the searchQuery string in fileSearch/filesSearch indicates AND in the query.  Using whitespace, two or more queries can be AND-ed.  See the last example in the doc.
https://doc.arcgis.com/en/cityengine/latest/cga/cga-file-search-function.htm
The same applies to other functions which use fileSearchassetApproxRatio, assetApproxSize, assetBestRatio, assetBestSize, assetFitSizefileRandomimageApproxRatioimageBestRatio
In order to put whitespace into a filepath, use single quotes:
filesSearch("'Wall Textures/*.png'")
Alternatively, the escape characters \s and \x20 also work to replace a space.  Note that an extra backslash is needed so the cga compiler interprets it correctly (instead of as a normal backslash).
filesSearch("Wall\\sTextures/*.png")
filesSearch("Wall\\x20Textures/*.png")
