Failing to correclty import terrain
1292
06-05-2014 03:40 AM
Briande_Vogel1
I'm trying to import a DEM into CE but it fails. When I import the DEM it is full with holes where the value of the raster is below zero.
Anyone knows what the problem is and how I could fix it?
cheers,
Brian
MatthiasBuehler1
Hey.
hmm. this sounds like a bug.
can you post the file with all metadata needed in a zip file ?
if you can't post the data, please send me a PM with your mail address.
as a workaround for now:
try to use the con()  from the raster calculator tool in ArcGIS to move up all points in the file by 50 meters. Then, in CE, use the terrain's vertical offset to move the terrain down by 50 meters.
Matt
Briande_Vogel1
The +50m did the trick!
Downsized the original to a 10m raster so it's a tad smaller but same problem/bug occurs.
cheers,
Brian
MatthiasBuehler1
thanks for the file ..
I'll have a look at it and log a bug.
Thanks for reporting.
Matt
