Esri Complete Street Rule Discussion-Feedback?
145085
223
12-11-2014 10:09 AM
DavidWasserman
Hi All,
My name is David Wasserman, the urban planner/programmer that wrote Complete_Street.cga that is featured in the Complete Street Example. I was hoping that if anyone had any comments on the rule or suggestions for changes/features/bug fixes I wanted to provide a forum for that on Geonet. So say what ever comes to your mind, but I would prefer constructive feedback. This could be a forum where everyone could provide input, discussion, and hopefully create a better rule. If you want to discuss transportation/parking/urban planning rules generally for CityEngine consider hitting this thread first.
I have attached some example renderings for those unfamiliar with the rule and its capabilities. In addition, there is now documentation for the rule available for download here. It is still pretty rough, so feedback is appreciated. In addition to the documentation, there is a new version of the rule posted about here, feedback would be appreciated.
In addition, this is also an ok forum if you are having problems with the rule. If you comment on here, I get buzzed. In the numbered section below I will recount a short summary of problems discussed in this thread.
Kind Regards,
David Wasserman
PS: If you  do anything with the rule or want to share a rendering you made (a nice one), feel free to share your images/experience.
Discovery 1: Webscene issues that were worked out pretty easily, small webscenes work typically better.
Discovery 2: Street rule is not compatible with CE 2013. Its Crosswalks Depend on 2014 UVSpace options, and there is not an ESRI.lib file for 2013. Rule is designed for and works best with the most recent version of CE (2014).
Discovery 3: For road segments to snap, you must make sure they are apart of the same layer. Merge layers if you have snapping problems.
Discovery 4: Short road segments are hard for the street rule to handle at times. A few work around with short segments include: Change crosswalks and stop types to none, making the CrosswalkBegin/End attributes a negative number, manipulating nodes to be longer, or deleting unnecessary nodes to create longer street segments (use simplify graph tool) (Thanks Steve).
Discovery 5: A discussion about curb extensions  and how to make them albeit an unorthodox way is both below and on this thread.
Discovery 6: Bridges have a minimum height requirement to generate (structure just does not make sense below a certain height). Also if you want Piers to appear regardless of Occlusion settings use On, Show All Piers. If it still does not work try: Making a new segment to test the rule one, restarting CE, or re-importing the road layer and starting again.
Discovery 7: When cropping or re-sizing your aerial for your CE project chances are you will need to georeference the image to your geography or another aerial. Georeferencing an aerial in ArcMAP will take on the ArcMAP scene projection but that is not enough. Be sure to use the "Project Raster" in the Toolbox and this will ensure proper scale and placement for your CE scene.
Discovery 8: Mapped Attributes: IF you map the streetWidth or sidewalk street parameters, and you want to adjust them after the fact you must change both the mapped object attribute AND the shape parameter. See responses below for details.
Discovery 9: Handles - Recent editions to the rule in 2017 have started to support handles for traffic lights and streetlights for more custom edits that were typically reserved for photoshop. If you have any suggestions for handles please add a comment.
_________________________________________________________________________________________________________________
Notice: 1: There is a 2015 Version of the Complete Street rule. There was a bug in the street rule that did not make it work in 2015, and in this version of the rule the bug is fixed. It should work in 2014 as well as 2015 versions of CE.
David Wasserman, AICP
Andy_Standley
Hi David.  I'm creating a narrow two lane bridge using 'Show All Piers', Bridge Starts At 3, Bridge Thickness 1, Pier Distance 23, Pier Width 2.3. I have tried different combinations. Is there any other situation where 'Show All Piers' doesn't work?.  Thanks, Andy
DavidWasserman
Hi Andy,
Let me investigate. Can I get your street width and sidewalk width settings?
Just a quick replication I got this.
David
Andy_Standley
Hi David. My street width does vary, four lanes running into two for the main span. The two lane street width is 9m, sidewalk width 2.5m.
Andy_Standley
Sorry David, I meant street width 11m, but I have tested various widths to see if it triggers anything with no luck. Andy
DavidWasserman
Whoa, so do you have Joint start shapes on this bridge?
Andy can you send me some screen shots?
Does concrete extrusion only do anything?
Andy_Standley
Hi David. I've tried creating a new road section, but no change. Is there a minimum elevation value by any chance?. Andybridge pier issue.jpg
Andy_Standley
Hi David. I've tried each of the Bridge Display options and have played with increased bridge height. Andy
DavidWasserman
Hi Andy,
I experimented a bit, and checked the code briefly. Yes, there is a height threshold. To check this please use the move tool to literally raise your bridge up?
It might be possible to use terrain off-sets, but essentially the bridge needs to be off the ground. Have you tried pre-processing the terrain in ArcMap?
David
Andy_Standley
Hi David. I removed the road section again and created the bridge with the freehand street creation tool, this works fine. I was using the polygonal street creation tool before. Thanks Andy
DavidWasserman
Huh. That is interesting. Can I see what the current bridge now?
