Esri Complete Street Rule Discussion-Feedback?
152198
223
12-11-2014 10:09 AM
DavidWasserman
Hi All,
My name is David Wasserman, the urban planner/programmer that wrote Complete_Street.cga that is featured in the Complete Street Example. I was hoping that if anyone had any comments on the rule or suggestions for changes/features/bug fixes I wanted to provide a forum for that on Geonet. So say what ever comes to your mind, but I would prefer constructive feedback. This could be a forum where everyone could provide input, discussion, and hopefully create a better rule. If you want to discuss transportation/parking/urban planning rules generally for CityEngine consider hitting this thread first.
I have attached some example renderings for those unfamiliar with the rule and its capabilities. In addition, there is now documentation for the rule available for download here. It is still pretty rough, so feedback is appreciated. In addition to the documentation, there is a new version of the rule posted about here, feedback would be appreciated.
In addition, this is also an ok forum if you are having problems with the rule. If you comment on here, I get buzzed. In the numbered section below I will recount a short summary of problems discussed in this thread.
Kind Regards,
David Wasserman
PS: If you  do anything with the rule or want to share a rendering you made (a nice one), feel free to share your images/experience.
Discovery 1: Webscene issues that were worked out pretty easily, small webscenes work typically better.
Discovery 2: Street rule is not compatible with CE 2013. Its Crosswalks Depend on 2014 UVSpace options, and there is not an ESRI.lib file for 2013. Rule is designed for and works best with the most recent version of CE (2014).
Discovery 3: For road segments to snap, you must make sure they are apart of the same layer. Merge layers if you have snapping problems.
Discovery 4: Short road segments are hard for the street rule to handle at times. A few work around with short segments include: Change crosswalks and stop types to none, making the CrosswalkBegin/End attributes a negative number, manipulating nodes to be longer, or deleting unnecessary nodes to create longer street segments (use simplify graph tool) (Thanks Steve).
Discovery 5: A discussion about curb extensions  and how to make them albeit an unorthodox way is both below and on this thread.
Discovery 6: Bridges have a minimum height requirement to generate (structure just does not make sense below a certain height). Also if you want Piers to appear regardless of Occlusion settings use On, Show All Piers. If it still does not work try: Making a new segment to test the rule one, restarting CE, or re-importing the road layer and starting again.
Discovery 7: When cropping or re-sizing your aerial for your CE project chances are you will need to georeference the image to your geography or another aerial. Georeferencing an aerial in ArcMAP will take on the ArcMAP scene projection but that is not enough. Be sure to use the "Project Raster" in the Toolbox and this will ensure proper scale and placement for your CE scene.
Discovery 8: Mapped Attributes: IF you map the streetWidth or sidewalk street parameters, and you want to adjust them after the fact you must change both the mapped object attribute AND the shape parameter. See responses below for details.
Discovery 9: Handles - Recent editions to the rule in 2017 have started to support handles for traffic lights and streetlights for more custom edits that were typically reserved for photoshop. If you have any suggestions for handles please add a comment.
_________________________________________________________________________________________________________________
Notice: 1: There is a 2015 Version of the Complete Street rule. There was a bug in the street rule that did not make it work in 2015, and in this version of the rule the bug is fixed. It should work in 2014 as well as 2015 versions of CE.
David Wasserman, AICP
DavidWasserman
Hey Wendell,
Generally when I want to do this, I copy paste the street segment in question and then move it to the side to be parallel to the same street, then change the settings till I get a trail like this one. I can investigate making a version that does this, but are you trying this work flow I mentioned above now?
David
Wendell_Dimaculangan
Hi David,
Thanks for your reply.  Generally we want the bike lanes as oart of the sidewalk,  same level and just different color/material/treatment  same as this photo.
DavidWasserman
Hi Wendell,
Please see the most recent rule here. This was actually a feature I tried to add a week ago...It really looks good on single cross sections and does not deal with joined streets very well. GitHub - Holisticnature/Complete_Street_Rule: This is an updated repository for a modified version o...
Go under Bicycle_Lane_Type--> Sidewalk
Then width added to bike lanes only applies to sidewalk side bike lanes. I added this to give a starting point to anyone who wanted to take the concept further...I have realized internationally this is one of the biggest asks of my rule. I have at least 3 different people from 3 different countries ask me for this feature at this point.
David
Thanks David I'll try it now.
DavidWasserman
Need feedback on it, but just keep in mind major modifications are out of scope for what I want to do with this feature.
David
This is great David (see attached) thanks! Is there a way to switch off the trees but retain the planting strips? I mostly render in Lumion and add the trees there.
DavidWasserman
Looks awesome. 😃
As specified in the documentation, you can remove trees by setting "Tree Percentage" to zero.
The Official Unofficial Guide to the ESRI Complete Street Rule.pdf
David, is there a way to have the Lamps in the median in the center? Right now it's either left or right or BOTH?
DavidWasserman
Oh...have not looked at that code in a while...ermm...I guess you could  modify the median so that it looked that way...
I can look into it. Now that you mention it...that should be a thing.
Hi David,
Is there a way on an intersection not to cut the Median? The vehicles from the street going to the boulevard will have to turn right only? (see attached)
Regards,
Wendell
