i am also facing the same problem.
i tried with all the solutions given here.
i am using 2017 version
Have we confirmed this is a problem or bug with 64-bit?
Hi,can you send me the most recent hs_err log file ?(check the creation date)let me know ..m.
Hi Helen,Here's the answer from the developer :Let me know if this helps.
Dear Helen,Cityengine comes with its own version of Java. Try adding java.exe from Cityengine/jre/bin to that whitelist.Then, depending on what mechanism your department uses, you might have to add all the dlls in the Cityengine/plugins/<xyz> directories as well. Your administrator should know more about that though.Cheers
HelloCollada .dae files that contain a light point seem to cause CityEngine to exit without warning.This happens whether I'm using the insert command or just clicking on the file in the Navigator window.I'm using CE 2011.2 - is there a list of bug fixes somewhere?
Hi Helen,Can you try the following :- Delete the folder C:\Users\<name>\AppData\LocalLow\Sun- Then try starting againLet me know..
hi Michael,can you post also the system specs like OS, amount of RAM, graphics card model ?first thing I'd try is update the graphics driver.let me know ..kind greetings !
