CityEngine 2013 Graphics Hardware Issue
3144
01-06-2014 12:25 AM
CarlBester
Hi All,
I have uninstalled CityEngine 2012 and installed CE 2013, but as soon as I try to install a Warning message appears stating that my Radeon HD 6470M is not supported. Everything worked fine on CE 2012, and I have not changed any hardware. Is there an explanation for this? Please see the attached screenshot.
Kind regards,
Carl
[ATTACH=CONFIG]30268[/ATTACH]
MatthiasBuehler1
Is it a laptop ?
I'm not sure if something has changed in this regard, but sometimes if it's a laptop, the 2nd graphics card may interfere.
Possibly you did set the deactivation setting for the 2nd card once before for CE2012 ?
Let me know ..
m.
CarlBester
Hi Matt,
Thanks for the response. It is a Laptop, but does not have a second graphics card. Also, I have not previously made any changes to the graphics activation settings when I used CE 2012.
Regards,
Carl
MatthiasBuehler1
Hi Carl,
I've just heard that it's a known issue, so it's on the bug list now.
Sad but true, but there's nothing I can do for you right in this moment .. 😞
m.
ps. do you have an other machine on which you could install ?
