Chamfer / bevel the edges of the geometry
3903
06-14-2012 08:32 AM
DavidOConnor
To make my building geometry look a bit more realistic, I'd like to chamfer / bevel all the edges in the model.  This will just soften them slightly, and make them look just a bit more realistic when rendered... because the light reflects differently off chamfered corners, and few real-world objects have knife-sharp edges.
Is there a simple way to do this?
I suspect it involves comp(e), but I'm not sure after that....
MatthiasBuehler1
hi !
Lot -->  extrude(10)  comp(f) {side : Bevel}  Bevel -->  roofGable(50,0,0,true) # use the vertical edge = rotate roof // angle must be larger than 45 degs because of following comp(f)   split(y){0.005: comp(f) {top : color(1,0,0) X. | all : X.}  | ~1 : NIL}
MatthiasBuehler1
hi !
DavidOConnor
Thank you Matthias, excellent help 😄
I played around with your suggestion, and this is what I came up with to fit my needs.
I share it here (liberally commented) because someone less experienced might find it useful.
Lot -->
 innerRect    // ensure the lot is a square, for simplicity
 alignScopeToAxes(y)   // these two lines ensure that
 s('1,0,'1)    // the lot is extruded vertically (world axes, not the local axes)
 extrude(10)
 comp(f) {top: Bevel | side : Bevel} // splits out the individual faces
Bevel -->
 roofHip(45)     // each face becomes a hip roof, relative to the local axes
 split(y){.1: comp(f) {bottom: NIL | all : Wall }}  // removes the bottom face (for efficiency)
Wall -->
 color(0,5,0)    // give it a pretty color :)
 Done.         // finished
[ATTACH=CONFIG]15266[/ATTACH]
MatthiasBuehler1
hey !
glad it works !
thanks for sharing ! :cool:
DavidOConnor
doh, I was implementing bevelled edges in LOD 0 of my city, and I realized that I forgot to take out the extra bit:
Lot -->
 extrude(10)
Bevel -->
 split(y){.1: comp(f) {bottom: NIL | all : Wall }  | ~1:NIL}  // removes the bottom face (for efficiency), then removes the excess
Wall -->
 Done.         // finished
