"Perspective could not be found"
1245
02-12-2013 06:09 AM
ScottFujikawa
Recently, when I start up CE, the program stalls and gives the error mesaage: "xxxxx\scenes\xxxxx.cej. perspective could not be found". I started getting this error message the day after I worked on xxxxx project and saved it before closing CE. How can I fix this?  I already re-opened and re-saved the project but I still keep getting this error message.
ScottFujikawa
Hi.
Changing the workspace seems to have resolved the error message when starting up. Thank you.
MatthiasBuehler1
Hi !
Did you try restarting in 'SafeMode' ?
If this does not help, the WorkSpace may be garbled.
You may need to create a new WorkSpace via File > Switch Workspace > Other ( edit the path to a new name ).
Then copy all projects on the harddrive into the new WS folder and link in all projects in CE.
m.
ScottFujikawa
Hi.
angeliaduan
restarting in 'SafeMode' should be work,i've tried before.
