Infographic designed in community analyst is not showing new updated data
1179
03-31-2020 03:38 PM
MichaelKimani
I have a question regarding the Community Analysts. Is it possible to have the info graphic produced be dynamic  in such way that once the data that is hooked on the web feature service  changes, the info graphic should change automatically because I have noticed that one has to export the info graphic again so that the new data can be seen.
Below is the info graphic am talking about the data coming from a web feature service has changed but the info-graphic has not https://coronavirusrcmrd.s3.amazonaws.com/Nairobi.html
SaraJK
I have the same question. Hoping to see a response.
FasilTiru
Hello Sara and Michael,
Although we don't have a specific time table when this functionality will be available, I would like to let you know that we are currently working on it as we've seen similar requests from other customers as well. When this is implemented, the exported infographics htmls will update dynamically when the data coming from a feature service is updated.
Fasil T.
Business Analyst Team
