How to calculate values from infographics generated from BA web app?
2023
04-26-2021 03:12 AM
ArockiyaM
Hi ,
I want to give value based on the demographic variables in the business analyst web app. for example,  population value  higher than 5000 I need to assign value 10. Where can I write these conditions in business analyst web app. This value should reflect in infographic report also. If i need to write scripting how to call the business analyst web app functions. Please suggest.
Fasil
@ArockiyaM
You can explore Conditional Styling options available when building your infographics. Depending on your infographic panel or table, you can set a text or image styling:
You can create text or image (supported for tables) styles as follows:
However, we currently do not have the specific option to assign a value for a range as you described above.
Fasil
BA Team
Fasil
@ArockiyaM
Fasil
BA Team
ArockiyaM
Thanks Fasil..!
