Add scale to the map of the business analyst reports
1063
03-22-2024 05:29 AM
DanielPadovaniEderli
How to add scales to the maps of the classic reports of Business Analyst?
DonnaBuhr
Esri Alum
Hi Daniel,
Are you asking about the Site Map report?
Best regards,
Donna
Hi, Donna, yes, when adding a map element, it doesn't bring a legend or scale. The legend can be solved by adding an image, but I haven't come up with any idea for the scale.
DonnaBuhr
Esri Alum
Hello Daniel,
The Site Map report should include the map scale, however, there currently seems to be an issue where the map scale is being mostly cutoff.  The map scale should appear in the lower left corner of the map and it is now only partially shown.
Thank you for reporting this issue.  We will work to resolve the problem as soon as possible.  As a temporary work-around, you might try adding the site to the map and creating a PDF.  The PDF includes the map scale.
We greatly appreciate your feedback and thank you for using Business Analyst!
Best regards,
Donna
