The ability to move the Items in the BAO Legend like how in ArcGIS online, the layers can be moved up or down in Details by selecting the item and moving to spot desired, or right-clicking on item, and select move up or move down.
When promoting this idea, could you please include a description of the use case for reordering layers in Business Analyst Online? Which layers would you like to reorder? How would you like to order them within the legend, and does this differ from how you want the layers ordered in the map?
I wanted to inform you that a Map Legend has been added in Business Analyst Web that allows layers to be moved up or down. In addition to rearranging layers, the Map Legend includes other helpful features, such as edit labels, remove layers, adjust the transparency and cluster points.
We hope you like the functionality of the Map Legend. Please let us know if you have other suggestions to improve the application.
Thank you for using Business Analyst Web and for your valuable feedback.
Best regards,
Donna
