Usually I use Business Analyst Online when performing a business search because it provides more options in terms of data sources. But there are times when I know a search will return more than 5,000 businesses, so I have to turn to Business Analyst for ArcGIS Pro instead. The NAICS codes in Pro are 8 digits, which is incredibly detailed. It's almost too much detail, in fact. Typically I just want to search at the 6 digit level. If I want to search for the 6 digit code 541611, there are 25 sub-codes that fall within that 6 digit code. So I then have to select each 8 digit code one by one to add it to the search. Being able to select all of the 8 digit sub-codes within a 6 digit code would save a lot of time.
Or just give us the option to search at the 6 digit level.
