Business Search using Data Axle includes the Industry Description in the results.
When exporting/saving the results as a layer to be used in additional mapping (web maps/apps), the Industry Description is left out.
Would like to query and symbolize by the Industry Description, which is more helpful for end users than NAICS/SIC codes.
Current workaround would be to export the Business Search results as an Excel table (which keeps the Industry Description) and then join that to the exported layer.
Hi Jonathan,
Thank you for bringing this issue to our attention. The "Industry Description" should be included when saving or sharing the business search layer. The feature was designed to work exactly as you have described; however it is not currently working as expected. This is a bug that we will fix in the next product release.
We greatly appreciate your valuable feedback and that you made us aware of the issue.
Thank you for using Business Analyst.
Best Regards,
Donna
The issue with the Industry Description has been fixed and is now working as expected in ArcGIS Business Analyst Web App.
Thank you,
