"Survey123 field app" to load a predetermined survey on startup
9994
32
01-22-2018 08:20 PM
by Anonymous User
Not applicable
I’d like to replicate the "Survey123 field app" to load a predetermined survey on startup.
Similar to how the Quick Report template works.
e.g. On startup I want it to look like a standalone application for collecting water quality data or collecting tree data, etc….
Any help is greatly appreciated
Gee
AurelieShapiro
Install the East Africa Mangrove App from the Google play store. There is no survey gallery.
Von: Dambé SANWOGOU
Gesendet: Dienstag, 16. April 2019 15:28
An: Shapiro, Aurelie
Betreff: Re: - Re: "Survey123 field app" to load a predetermined survey on startup
GeoNet <https://community.esri.com/?et=watches.email.thread>
reply from Dambé SANWOGOU<https://community.esri.com/people/s_anselme?et=watches.email.thread> in AppStudio for ArcGIS - View the full discussion<https://community.esri.com/message/846218-re-survey123-field-app-to-load-a-predetermined-survey-on-startup?commentID=846218&et=watches.email.thread#comment-846218>
DambéSANWOGOU
Yes, I installed it. There is no Gallery in your application but I have the same code you sent me. That's what I don't understand!
9a1b952e808c445a9fdefbaba6d5d6ac.zip - Google Drive
Best regards,
Anselme
AurelieShapiro
You need to open in qml editor and search for the keywords..
Von: Dambé SANWOGOU
Gesendet: Dienstag, 16. April 2019 16:01
reply from Dambé SANWOGOU<https://community.esri.com/people/s_anselme?et=watches.email.thread> in AppStudio for ArcGIS - View the full discussion<https://community.esri.com/message/846219-re-survey123-field-app-to-load-a-predetermined-survey-on-startup?commentID=846219&et=watches.email.thread#comment-846219>
YuliaMamonova
Hey,
Could you please let me know if you made it work? I have the same issue - I added that piece of code, but the app still opens the gallery. Would appreciate your help!
DambéSANWOGOU
Yulia Mamonova‌ Hi, I have the same problem, but after several attempts I gave up.
AndrewKniowski1
Note:  A quick modification to the suggestion by Erwin that seems to correct the survey not loading issue for current versions of the app.
Edit the template/SurveyApp.qml file instead of the file previously mentioned.  Locate the Component.onCompleted method for the root App component near the top of the file.  The method already has several lines of code.  Scroll to the bottom of the method and add the app.openParamaters code directly above initialized = true.   It is important that the code be added at the bottom of the method.  The survey gallery page may very briefly be visible using this app modification method but the survey should automatically load.
YuliaMamonova
Thank you Andrew for the suggestion!
Is it going to open the survey page (where you can review different survey folders - sent, outbox etc.) or the survey itself?
Thinkoutsidescott
Hi Erwin, how can I do this same thing in the newest version of  Survey123? I do not see Survey Gallery Page available.
If possible I'd also like the app to skip the required log in page and go straight to the Survey Gallery where my public survey would theoretically appear. I am trying to make it as simple as possible for users to download my white labeled Survey123 app and only see the survey that I would like them to complete without having to do any extra steps to download the survey.
Thank you,
Scott
AlexP_
I see it is display and open only one survey.  Is it possible to display more than one survey (public)? Please let me know.
Thank you.
Alex
YuliaMamonova
Alex,
Did you try parsing several item ids? I also have this question as I am working on the new app, and will soon need to load several predetermined surveys.
