Problem with FolderListModel on Android 10
2094
07-08-2021 04:13 AM
JorgeFrade_Martínez
Hi!
Im using the FolderListModel  to make a custom file chooser, works perfectly on Windows, iOS and Android 11.
The problem is that on Android 10, do not work at all...
Can you provide me some help with this?
import QtQuick 2.9
import QtQuick.Controls 2.2
import QtQuick.Window 2.2
import Qt.labs.folderlistmodel 2.2
import ArcGIS.AppFramework 1.0
Rectangle {
    visible: false
    width: 640
    height: 480
    Rectangle {
        x: 20
        y: 20
        width: 300
        height: 450
        border.color: "black"
        radius: 30
        ListView {
            y: 30
            width: parent.width
            height: parent.height - 60
            clip: true
            model: FolderListModel {
                showDirsFirst: true
                folder: "file:///" + AppFramework.standardPaths.defaultFolder(StandardPaths.DownloadLocation).path
//                nameFilters: ["*.mp3", "*.flac"]
            delegate: Button {
                width: parent.width
                height: 50
                text: fileName
                onClicked: {
                    if (fileIsDir) {
                        folderListModel.folder = fileURL
                background: Rectangle {
                    color: fileIsDir ? "orange" : "gray"
    Button {
        anchors.left: mainRect.right
        anchors.leftMargin: 5
        text: "back"
        onClicked: folderListModel.folder = folderListModel.parentFolder
ErwinSoekianto
Esri Alum
@JorgeFrade_Martínez
That is weird, I have a feeling it might related to the StandardPath, can you try different standard path options to see if we are still seeing the same issue?
https://developers.arcgis.com/appstudio/api-reference/qml-arcgis-appframework-standardpaths/
Erwin.
JorgeFrade_Martínez
Hi @ErwinSoekianto !
I try all the others Standard Paths without success. I also tried hardcoding some paths but with the same result...
