create a qml object using javascript
2232
01-11-2021 03:38 AM
rsharma
hi
i want to create qml object of the below code. can anyone help
NetworkRequest {
    url: "http://appstudio.arcgis.com/images/index/introview.jpg"
    responsePath: fileFolder.path +"/appstudio.jpg"
    property url imagePath: responsePath
   onReadyStateChanged: {
        console.log("Ready state"+readyState);
        if (readyState == NetworkRequest.DONE) {
        image.source = internal.folderUrl+"/appstudio.jpg";
   //onProgressChanged: console.log("progress:", progress)
    onError: {
        console.log(errorText + ", " + errorCode)
        //On failure, don't use the local copy
        image.source = ""
SeanKim
Just for your reference.
var newObj = Qt.createQmlObject("import QtQuick 2.12;import ArcGIS.AppFramework 1.0; NetworkRequest{id:networkRequest}", root, "");
newObj.onReadyStateChanged.connect(function f(){
    console.log("Ready state:" + newObj.readyState)
    if (newObj.readyState === NetworkRequest.DONE){
        console.log("done")
newObj.url = "http://appstudio.arcgis.com/images/index/introview.jpg"
newObj.send();
ErwinSoekianto
Esri Alum
@rsharma
Did you mean creating QML objects dynamically? Take a look at this, https://doc.qt.io/qt-5/qtqml-javascript-dynamicobjectcreation.html
Erwin
SeanKim
        console.log("done")
newObj.send();
rsharma
hi @SeanKim
when i check for newtworkrequest done, it always give me the error
        console.log("done")
ReferenceError: NetworkRequest is not defined
so i tried like this way
if(newObj.readyState===4){
            console.log("done");
            DB.insertMediaDetails(dev_href_fname,ref_no,ref_type);
            console.log("done inserting");
            return dev_href_fname;
calling fnc DB.insertMediaDetails(dev_href_fname,ref_no,ref_type);
 but it always return  fron this cond before readystate become 4 and return undefined
