GIS Feature Query Task Failure: System.Security.SecurityExpection SilverLight
Please see screenshot below.. Using internet explorer 11.9 with silverlight installed 5.1.5. Please advise. Thank you.
Can't find ESRI.ArcGIS.Client ...
Recently, I switched to a new PC. For my Silverlight projects, I downloaded and then installed Silverlight SDK 5.from Download Microsoft® Silverlight® 5 SDK from Official Microsoft Download Center . Then I opened my Silverlight project, but could not find ESRI.ArcGIS.Client.dll, ... as references. Since I haven't touch the…
A security exception occurred while trying to connect to the 'WMS' service
Please refer my previous question in the link given below. https://community.esri.com/message/858968-re-issue-in-accessing-wms-layers-in-arcgis-api-31-for-silverlight?commentID=858968&et=watches.email.thread#comment-858968 I am trying to add WMS layer published on GeoServer using the code given below var wmsLayer = new…
Issue in accessing WMS layers in ArcGIS API 3.1 for Silverlight
We have developed an ArcGIS based Web application using .net Silverlight framework (version 5).The application consumes various layers published in ArcGIS server and displays them on the map. Technologies used to develop the web application :.Net framework version – 4.0Silverlight Version – 5.1.50901.0ESRIArcGIS.Client –…
Adding WMS layers ArcGIS API 3.1 for Silverlight & ESRI.ArcGIS.Client.Toolkit.DataSources toolkit
I am trying to add a WMS layer using ESRI.ArcGIS.Client.Toolkit.DataSources toolkit to an ArcGIS Server 10.3 web application has been designed using Silverlight version 5 ArcGIS API 3.1 for Silverlight. It appears that ESRI.ArcGIS.Client.Toolkit.DataSources toolkit has been removed from official ArcGIS website for…
How to add wms layer in arcgis silverlight application?
We need to use wms service to display the data in the map. I referred the websites given below. https://community.esri.com/thread/69289 http://resources.arcgis.com/en/help/runtime-wpf/concepts/index.html#//017000000084000000 When I try to add <SPAN class="" style="color: #303336; border: 0px; font-weight: inherit;…
How to Get polygon points from Geometry in Xamarin Android?
I have drawn polygon using SketchEditor Xamarin (Android & iOS) Geometry geometry = await _mapView.SketchEditor.StartAsync(SketchCreationMode.Polygon, true); Now I want to get the lat longs. How can I get lat long of all points? Please help me I'm not getting any references for Xamarin Android & iOS.
Line through polygons spanning 180-degree line
I am trying to render a shapefile with polygons in the Pacific Ocean, which span the 180-degree line. The resulting image shows a line going through the polygons at the meridian, and I would like to know how to avoid this. Note: the polygons are not split into separate features in the attribute table, they are simply…
I Need Silverlight API 3.3 x64 (Urgent)
Hello. We facing some Internet Explorer memory limitations problem on clients. We using Arcgis api for silverlight 3.3 (x32) And wee need to x64 silverlight API. (Client, Client.Behaviors, Client.Bing, Client.Printing, Client.Toolkit, Client.Toolkit.DataSources). This is very urgent. I've downloaded sources from…
shape file for SL
I decided to replace our Arc GIS Viewer for Flex with ArcGIS Viewer for silverlight. So far the setup is going well, however the key tool/widget i need is the shapefile widget to load exploration shape file data. But it seems the SL version does not contain that as a tool. Anyone know how I can download the shapefile…
Editing table in Silverlight 5
I'm trying to use this example: Editing Tables in Feature Service with Silverlight 4 with Silverlight 5. I get the dataform populated but the new feature isn't getting saved. In the debugger, I can see the 'hasEdits' flag is false after the new graphic is added. Has anyone successfully edited a table using Silverlight 5?
Silverlight Bing Geocoder not working
I have a Silverlight application that up until the past few days has been functioning without issue, but now I'm getting an exception from the Bing Geocoder. After three days of debugging I'm at my wit's end. I have made sure I'm on the latest version of ArcGISSilverlight-Bing available from NuGet (3.3.0.33). Here is the…
How to get center of circle when we use Draw.js in arcgis 3.x version?
i had completed drawing circle in arcgis map but need to find the center and radius of the circle? Can anyone please help?
Silverlight API editor widget- domains do not display as a dropdown list unless the layer is using unique value symbology
I have ran into a strange issue with the Silverlight API editing widget. When attempting to edit a feature from a layer with a simple renderer, for the fields with domains applied, only the domain code displays in the field, and no dropdown list is available: However, if I change the symbology to a unique value renderer,…
svg image as picturemarkersymbol source
Hello. I'm using silverlight ana I have got a svg image <svg version="1.1" xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink" x="0px" y="0px" width="100px" height="100px" viewBox="0 0 100 100" enable-background="new 0 0 100 100" xml:space="preserve"><circle fill="#1c437a" cx="51" cy="52"…
WrapAround makes all MultiPoints move when one point is moved (Silverlight)
I was wondering if anyone experienced the following issue on Silverlight API (know is out of production but looking for advice). When I create a simple map with wraparound enabled and add 3 MapPoints to the Multipoint to add to the map. When I pan on the map, when the right most point hits the edge and moves to the other…
Can't add Graphic to a GraphicsLayer
This is .Net (Silverlight) program. I want to add a Graphic item to a GraphicsLayer. The related code is listed below GraphicsLayer newGLyr = new GraphicsLayer(); for (int i = 0; i < gLayer.Graphics.Count; i++) { Graphic g = gLayer.Graphics; if (!isDuplicate(newGLyr, g)) newGLyr.Graphics.Add(g); } However, I got the…
Silverlight application is not able to consume services after upgrading the ArcGIS server to 10.5 version
I have upgraded my ArcGIS server to 10.5 and published all the services that was running on the old version. I have the the same REST URL for the newly published service as of old service and I have stopped the old service in the older version of ArcGIS. When I am trying to consume the new service published on ArcGIS 10.5…
programmatically add a unique ID to feature layer attribute
Hi all, I am using ken's code to update/add projects to feature layer: array<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN>featureSet<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation…
Edit widget in AWAB
Hi - I am working on customisation of AWAB Edit widget in AGOL. I want to diable the 'Delete' functionality from the widget but users can add the feature. Basically remove the 'Delete' button from the Edit tool popup window. Thanks in advance Ramesh
Getting sub layers from ArcGISDynamicMapservice
I have a rest service url which I have used to create dynamic service and added it to the map. I want to loop through the arcgis dynamic map service layer to access feature layers in it.Is there any way to access feature layers in arcgis dynamic layer ?
Silverlight 2.4 API and Server 10.2.2
Does anyone have an experience, positive or negative, migrating their services to 10.2.2 server but continuing to use 2.4 API? We need to move to a new server, but don't have time to upgrade the API. Our other option would be to slam those services into Portal and give our users about 80% of their functionality for this…
Crossing dateline with a shape and editing
Hi, If I draw a shape across the dateline then edit the shape programmatically, the shape redraws the wrong way around the world (a short line from Russia to Alaska goes the long way around the world). Is that an API bug? Is it fixable with a band-aide? I saw that the JavaScript API has a bug fix for crossing the dateline…
DOMAIN AND SUB TYPE VALUES
I need an urgent help with Arc Gis silver light application, INFO WINDOW is not showing domain and sub type values and i didn't find any good solution to handle this bug. Kindly any one who know how to solve this issue let me know on urgent basis your help will be appreciated a lot and i will be great thankful to...…
Where can I download ArcGIS for Silverlight 3.1?
Needed for legacy SL4 app. Thanks
