ZoomTo Bing Geocode BestView for United States
1309
11-25-2011 01:26 AM
ChrisSmith
Hi
Using ESRI Bing geocoder for search address 'United States' the best view returned is :
SouthWest.Lon = 177.348754
SouthWest.Lat =26.677207
NorthEast.Lon = -55.848747
NorthEast.Lat = 75.762794
When creating points and converting from WGS84 to WebMercator then constructing an Envelope for the Map to ZoomTo(), the map zooms to Europe, Asia & North Africa.
When drawing out the coordinates on paper the best view spans the date line (I have tried Geometry.NormalizeCentralMeridian())
Here is some sample code...(coordinates have been hardcoded and switched round multiple times in the new Envelope() constructor in an attempt to try and get it to work)
var southWest = Transform.GeographicToWebMercator(new MapPoint(177.348754, 26.677207, new SpatialReference(4326)));
var northEast = Transform.GeographicToWebMercator(new MapPoint(-55.848747, 75.762794, new SpatialReference(4326)));
var envelope = new Envelope(northEast.X, southWest.Y, southWest.X, northEast.Y);
envelope.SpatialReference = new SpatialReference(102100);
SomeMap.ZoomTo(Geometry.NormalizeCentralMeridian(envelope));
am I missing anything obvious?
any pointers/help would be much appreciated
Chris
ChrisSmith
bit more info, normalizing the geometry doesn't update it...
before normalizing to central meridian...
envelope
{-6217054.07748237,3083200.58936723,19742372.9881015,13268766.2816879}
    base {ESRI.ArcGIS.Client.Geometry.Geometry}: {-6217054.07748237,3083200.58936723,19742372.9881015,13268766.2816879}
    Extent: {-6217054.07748237,3083200.58936723,19742372.9881015,13268766.2816879}
    Height: 10185565.692320695
    Width: 25959427.065583907
    XMax: 19742372.988101542
    xmax: 19742372.988101542
    xmin: -6217054.077482366
    XMin: -6217054.077482366
    ymax: 13268766.281687925
    YMax: 13268766.281687925
    YMin: 3083200.58936723
    ymin: 3083200.58936723
after normalizing to central meridian...
normalizedEnvelope
    [ESRI.ArcGIS.Client.Geometry.Envelope]: {-6217054.07748237,3083200.58936723,19742372.9881015,13268766.2816879}
    GeometryChanged: null
    SpatialReference: {ESRI.ArcGIS.Client.Geometry.SpatialReference}
