Zoom to a set scale similar to ArcIMS
2255
01-06-2012 03:41 PM
ChristineZeller
I was wondering if there was an that showed how to set up a task to zoom to set scale (user types in the scale or maybe even a drop down/combo box with some predefine scales; ex 1:200, 1:400, 1:1000).  I was thinking since most of use have our imagery cached at standard ESRI scales or are using ESRI imagery services maybe there is a way just to take advantage of that.  It seems like the navigation zoom in and zoom out toolbar is following the cached  tiling scheme / define scales levels of the cache.
Any help or reference would be great!
Thanks
Chris
DominiqueBroux
Esri Frequent Contributor
That's depending on the 'SnapToLevels' map property. If you set it to false, you will be able to zoom at any scale.
From 2.3, scale support has been added to the Map. See a sample here : http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#MapScale
Nevertheless the Scale property is read-only. To change the scale you can use ZoomToResolution.
Code snippet setting the map scale to 1:10000 :
double expectedScale = 10000.0;
map.ZoomToResolution(map.Resolution * expectedScale / map.Scale);
Note : Take care that 'map.Scale' is not really the scale but the scale denominator.
dotMorten_esri
Esri Notable Contributor
Also note that this assumes your monitor has a DPI of 96 (which it most likely doesn't).
