TimeSlider and GeoRssLayer
850
08-12-2010 08:52 PM
linusang
Hi i managed to hook up the TimeSlider and GeoRssLayer...
however i have some issues...
1) is there a way when i scrub the slider, the changes appears on the fly instead of appearing when i release the slider's thumb..
2) how to make the play button appear on the TimeSlider control?
thanks....
DominiqueBroux
Esri Frequent Contributor
I didn't find out any way to change the time extent value on the fly.
By default the play button appears on the TimeSlider control. You can remove this button or change it by editing the time slider template
linusang
The play button doesn't show even if i set the visibility to visible in the template.. there must be some behavior which overrides this setting....
JenniferNery
