Silverlight API 3.2 Samples
1761
06-16-2014 11:32 AM
ELIZABETH50
I'm trying to add a sample to the ESRIStandardMapapplication template, but I'm having a hard time using the same map.  How can I use the same map without adding all the xmal code into the MainPage.xaml, I'd like to keep it in folders.
I want this to bind this to the Map! How can I do this?
<esri:Map x:Name="MyMap" Extent="-118.331,33.7,-116.75,34" >
                <esri:ArcGISTiledMapServiceLayer ID="StreetMapLayer"
                      Url="http://services.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer"/>
                <esri:GraphicsLayer ID="MyGraphicsLayer" />
</esri:Map>
This is on the MainPage.xaml:
     <esri:Map x:Name="Map" Background="White" WrapAround="true">
            <i:Interaction.Triggers>
                <i:EventTrigger EventName="MouseEnter">
                    <ei:ChangePropertyAction TargetName="myMenuItems" PropertyName="Visibility">
                        <ei:ChangePropertyAction.Value>
                            <Visibility>Collapsed</Visibility>
                        </ei:ChangePropertyAction.Value>
                    </ei:ChangePropertyAction>
                </i:EventTrigger>
            </i:Interaction.Triggers>
         <esri:ArcGISTiledMapServiceLayer ID="BaseLayer"
          Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer" />
        </esri:Map>
AhmedEl-Sisi
Hi Eliza,
You can make a DependencyProperty in your new control then pass the map object to it.
Check the attached sample.
Regards,
ELIZABETH50
The dependency property works with any silverlight sample.  I'm still confuse?
AhmedEl-Sisi
It depends on what you want, but basically if you want to pass object from your MainPage -which hosts your controls- to your child controls, you can use dependency property as you can bind to it.
