QueryTask Events are not accessible in Silverlight API
1901
04-19-2010 08:04 PM
SourishChakraborty
I am using Silverlight API and VS2008 with SP1.I am unable to access QueryTAsk Events like ExecuteCompleted,Failed and PropertChanged from VB.NET code.It's possible to access these events from C#.NET code.
Can anybody tell me ,if I am skipping something.Is there anyway to access those public events from VB.NET code.
Is I am missing some fundamental things of .NET concept.
Please guide.
Thanks & Regrads
HubertLo
I have no problem accessing it when I tested it in a sample project of mine. I am sure you can do this in VB.NET if you change the syntax from C#. Here are the snippets of the code from my sample project:
Calling the QueryTask
ESRI.ArcGIS.Client.Tasks.QueryTask queryTask =
    new QueryTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/Map...");
queryTask.ExecuteCompleted += queryTask_ExecuteCompleted;
ESRI.ArcGIS.Client.Tasks.Query query = new ESRI.ArcGIS.Client.Tasks.Query();
query.Geometry = MyMap.Extent;// geoRectangle;
query.OutSpatialReferenceWKID = MyMap.SpatialReference.WKID;
query.ReturnGeometry = true;
query.SpatialRelationship = SpatialRelationship.esriSpatialRelIntersects;
query.OutFields.AddRange(new string[] { "FID", "CITY_NAME", "STATE_NAME", "POP1990 " });
queryTask.ExecuteAsync(query);
The ExecuteCompleted event handler
void queryTask_ExecuteCompleted(object sender, QueryEventArgs args)
    ESRI.ArcGIS.Client.Tasks.FeatureSet featureSet = args.FeatureSet;
    if (featureSet == null || featureSet.Features.Count < 1)
        MessageBox.Show("No features retured from query");
        return;
    GraphicsLayer graphicsLayer = MyMap.Layers["SQL2008Spatial"] as GraphicsLayer;
    foreach (Graphic graphic in featureSet.Features)
        if (graphic.Geometry.Extent.YMax == graphic.Geometry.Extent.YMin)
            graphic.Symbol = DefaultPointMarkerSymbol;
        else
            graphic.Symbol = DefaultLineSymbol;
        graphicsLayer.Graphics.Add(graphic);
SourishChakraborty
I have used the C# code,it's working fine but while using the VB.NET code intellisense is not showing the Public events like "ExecuteCompleted" etc.
See the snapshot of the intellisense attached.
Thanks & Regrads
LanceCrumbliss
i think you'll need to use the AddHandler statement in order to access the events, ie
Dim queryTask as New QueryTask(url)
AddHandler queryTask.ExecuteCompleted, AddressOf queryTask _ExecuteCompleted
and then write the event handler "queryTask_ExecuteCompleted"
 Private Sub queryTask_ExecuteCompleted(ByVal sender As Object, ByVal args As QueryEventArgs)
             'Do amazing things
 End Sub
lance
SourishChakraborty
Yup!11...Done...
Thanks & Regards
