using System; using System.Collections.Generic; using System.Linq; using System.Net; using System.Windows; using System.Windows.Browser; using System.Windows.Controls; using System.Windows.Documents; using System.Windows.Input; using System.Windows.Media; using System.Windows.Media.Animation; using System.Windows.Markup; using System.Windows.Shapes; using System.ComponentModel; using ESRI.ArcGIS.Client; using System.Windows.Controls.Primitives; namespace ESRIStandardMapApplication1 { public partial class MainPage : UserControl { public MainPage() { InitializeComponent(); } private void myMenuItem1_Click(object sender, RoutedEventArgs e) { // The myArcGISDynamicMapServiceLayer (an ArcGISDynamicServiceLayer object) and TextBlock_LayerDefinitions // (a TextBlock object) were defined previously in the XAML or code-behind. // Get the layer in the LayerInfo collection. ArcGISDynamicMapServiceLayer myArcGISDynamicMapServiceLayer = (ArcGISDynamicMapServiceLayer)Map.Layers[1]; // LayerDefinition (Read/Write) // This is how to set (i.e. Write) a LayerDefinition. // -------------------------------------------------- // Set the .LayerDefinition for the .LayerID = 0 (the Earthquakes1970 layer). By default no LayerDefinition // is set unless explicitly set on the server. ESRI.ArcGIS.Client.LayerDefinition myDefinition = new ESRI.ArcGIS.Client.LayerDefinition(); myDefinition.LayerID = 0; // The Definition only displays earth quakes that have an Magnitude greater than 6. // The field Magnitude is of type esriFieldTypeDouble. myDefinition.Definition = "Magnitude > 6"; // Another example where the Name of the earth quake event is to contains the letters 'CHINA'. // Note: the Definition is case sensitive. The field Name is of type esriFieldTypeString. //myDefinition.Definition = "Name LIKE 'CHINA'"; // Another example where the Name of the earth quake event is exactly matches the letters 'VENEZUELA'. // Note: the Definition is case sensitive. The field Name is of type esriFieldTypeString. //myDefinition.Definition = "Name = 'VENEZUELA'"; // Another example where the earth quake events are displayed if they occured after January 15, 2008. // The field Date_ is of type esriFieldTypeDate. //myDefinition.Definition = "Date_ > DATE '1/15/2008'"; // Create an ObservableCollection and add the .Definition to it. System.Collections.ObjectModel.ObservableCollection<LayerDefinition> myObservableCollection2 = new System.Collections.ObjectModel.ObservableCollection<LayerDefinition>(); myObservableCollection2.Add(myDefinition); // Apply the custom LayerDefinition myArcGISDynamicMapServiceLayer.LayerDefinitions = myObservableCollection2; myArcGISDynamicMapServiceLayer.Refresh(); } private void myMenuItem2_Click(object sender, RoutedEventArgs e) { // The myArcGISDynamicMapServiceLayer (an ArcGISDynamicServiceLayer object) and TextBlock_LayerDefinitions // (a TextBlock object) were defined previously in the XAML or code-behind. // Get the layer in the LayerInfo collection. ArcGISDynamicMapServiceLayer myArcGISDynamicMapServiceLayer = (ArcGISDynamicMapServiceLayer)Map.Layers[1]; // LayerDefinition (Read/Write) // This is how to set (i.e. Write) a LayerDefinition. // -------------------------------------------------- // Set the .LayerDefinition for the .LayerID = 0 (the Earthquakes1970 layer). By default no LayerDefinition // is set unless explicitly set on the server. ESRI.ArcGIS.Client.LayerDefinition myDefinition = new ESRI.ArcGIS.Client.LayerDefinition(); myDefinition.LayerID = 0; // The Definition only displays earth quakes that have an Magnitude greater than 6. // The field Magnitude is of type esriFieldTypeDouble. myDefinition.Definition = "Name = 'VENEZUELA'"; // Another example where the Name of the earth quake event is to contains the letters 'CHINA'. // Note: the Definition is case sensitive. The field Name is of type esriFieldTypeString. //myDefinition.Definition = "Name LIKE 'CHINA'"; // Another example where the Name of the earth quake event is exactly matches the letters 'VENEZUELA'. // Note: the Definition is case sensitive. The field Name is of type esriFieldTypeString. //myDefinition.Definition = "Name = 'VENEZUELA'"; // Another example where the earth quake events are displayed if they occured after January 15, 2008. // The field Date_ is of type esriFieldTypeDate. //myDefinition.Definition = "Date_ > DATE '1/15/2008'"; // Create an ObservableCollection and add the .Definition to it. System.Collections.ObjectModel.ObservableCollection<LayerDefinition> myObservableCollection2 = new System.Collections.ObjectModel.ObservableCollection<LayerDefinition>(); myObservableCollection2.Add(myDefinition); // Apply the custom LayerDefinition myArcGISDynamicMapServiceLayer.LayerDefinitions = myObservableCollection2; myArcGISDynamicMapServiceLayer.Refresh(); } void ReadLayerDefs() { // This is how to get (i.e. Read) a LayerDefiniton. // The TextBlock_LayerDefinitions (a TextBlock object) was previously set in XAML or code-behind. // ---------------------------------------------------------------------------------------------- // Get the existing LayerDefinitions collection. ArcGISDynamicMapServiceLayer myArcGISDynamicMapServiceLayer = (ArcGISDynamicMapServiceLayer)Map.Layers[1]; System.Collections.ObjectModel.ObservableCollection<LayerDefinition> myObservableCollection = myArcGISDynamicMapServiceLayer.LayerDefinitions; if (myObservableCollection.Count > 0) { // Get the first LayerDefinition ESRI.ArcGIS.Client.LayerDefinition myLayerDefinition = myObservableCollection[0]; // Display some textual information about the LayerDefinition. MessageBox.Show("For Layer: " + myLayerDefinition.LayerID.ToString() + ". The Defintion is: " + myLayerDefinition.Definition); } else { MessageBox.Show("[NO LayerDefinitions SET]"); } } private void myMenuItem3_Click(object sender, RoutedEventArgs e) { // Get the layer in the LayerInfo collection. ArcGISDynamicMapServiceLayer myArcGISDynamicMapServiceLayer = (ArcGISDynamicMapServiceLayer)Map.Layers[1]; // Create an ObservableCollection and add the .Definition to it. System.Collections.ObjectModel.ObservableCollection<LayerDefinition> myObservableCollection2 = new System.Collections.ObjectModel.ObservableCollection<LayerDefinition>(); // myObservableCollection2.Add(myDefinition); // Apply the custom LayerDefinition myArcGISDynamicMapServiceLayer.LayerDefinitions = myObservableCollection2; myArcGISDynamicMapServiceLayer.Refresh(); } } }
<UserControl x:Class="ESRIStandardMapApplication1.MainPage" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:d="http://schemas.microsoft.com/expression/blend/2008" xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006" xmlns:esri="http://schemas.esri.com/arcgis/client/2009" mc:Ignorable="d" d:DesignWidth="780" d:DesignHeight="480" xmlns:i="clr-namespace:System.Windows.Interactivity;assembly=System.Windows.Interactivity" xmlns:ei="clr-namespace:Microsoft.Expression.Interactivity.Core;assembly=Microsoft.Expression.Interactions" xmlns:userControls="clr-namespace:ESRI.ArcGIS.SilverlightMapApp" xmlns:actions="clr-namespace:ESRI.ArcGIS.SilverlightMapApp.Actions"> <Grid x:Name="LayoutRoot"> <!-- Map Control --> <esri:Map x:Name="Map" Background="White"> <i:Interaction.Triggers> <i:EventTrigger EventName="MouseEnter"> <ei:ChangePropertyAction TargetName="myMenuItems" PropertyName="Visibility"> <ei:ChangePropertyAction.Value> <Visibility>Collapsed</Visibility> </ei:ChangePropertyAction.Value> </ei:ChangePropertyAction> </i:EventTrigger> </i:Interaction.Triggers> <esri:ArcGISTiledMapServiceLayer ID="BaseLayer" Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer" /> <esri:ArcGISDynamicMapServiceLayer Url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Earthquakes/Since_1970/MapServer"> <esri:ArcGISDynamicMapServiceLayer.LayerDefinitions> <!-- LayerID="0" is the Earthquakes1970 layer. The Definition only displays earth quakes that have an Magnitude greater than 6. The field Magnitude is of type esriFieldTypeDouble. --> <!-- <esri:LayerDefinition LayerID="0" Definition="Magnitude > 6" /> --> <!-- Another example where the Name of the earth quake event is to contains the letters 'CHINA'. Note: the Definition is case sensitive. The field Name is of type esriFieldTypeString. --> <!-- <esri:LayerDefinition LayerID="0" Definition="Name LIKE 'CHINA'" /> --> <!-- Another example where the Name of the earth quake event is exactly matches the letters 'VENEZUELA'. Note: the Definition is case sensitive. The field Name is of type esriFieldTypeString. --> <!-- <esri:LayerDefinition LayerID="0" Definition="Name = 'VENEZUELA'" /> --> <!-- Another example where the earth quake events are displayed if they occured after January 15, 2008. The field Date_ is of type esriFieldTypeDate. --> <!-- <esri:LayerDefinition LayerID="0" Definition="Date_ > DATE '1/15/2008'" />--> </esri:ArcGISDynamicMapServiceLayer.LayerDefinitions> </esri:ArcGISDynamicMapServiceLayer> <!--<esri:ArcGISDynamicMapServiceLayer ID="Base Map" Url="http://ccmcd-gis/ArcGIS/rest/services/Citrus_Base/MapServer" />--> </esri:Map> <!-- Main Menu --> <Grid HorizontalAlignment="Left" VerticalAlignment="Top" Margin="10" > <userControls:CollapsiblePanel x:Name="MainManu" IsExpanded="True" RenderTransformOrigin="0,0" VerticalContentAlignment="Stretch" HorizontalContentAlignment="Stretch"> <Border Style="{StaticResource CommonBorder}"> <StackPanel Margin="3"> <Grid x:Name="BannerGrid" Grid.Row="0" Margin="30,0"> <Grid.RowDefinitions> <RowDefinition Height="30" /> <RowDefinition Height="3" /> <RowDefinition Height="17" /> </Grid.RowDefinitions> <!-- Application Title --> <TextBlock x:Name="title" Margin="0,0,15,0" Style="{StaticResource Title}" Text="{StaticResource ApplicationTitle}" Grid.Row="0" /> <Rectangle x:Name="separatorBar" Fill="CornflowerBlue" Grid.Row="1" /> <!-- Application Subtitle --> <TextBlock x:Name="subtitle" Style="{StaticResource Subtitle}" Text="{StaticResource ApplicationSubtitle}" Grid.Row="2" /> </Grid> <Canvas HorizontalAlignment="Left" Height="25" Width="Auto" VerticalAlignment="Bottom" Margin="10,10,10,-5"> <StackPanel Orientation="Horizontal"> <Button x:Name="myMenu" Style="{StaticResource MenuButton}" ToolTipService.ToolTip="Menu"> <Button.Content> <Image Source="Images/i_globe.png" Stretch="Fill" /> </Button.Content> <i:Interaction.Triggers> <i:EventTrigger EventName="MouseEnter"> <ei:ChangePropertyAction TargetName="myMenuItems" PropertyName="Visibility"> <ei:ChangePropertyAction.Value> <Visibility>Visible</Visibility> </ei:ChangePropertyAction.Value> </ei:ChangePropertyAction> </i:EventTrigger> </i:Interaction.Triggers> </Button> <Button x:Name="btnAbout" Style="{StaticResource MenuButton}" ToolTipService.ToolTip="About ESRI ArcGIS Mapping Application"> <Button.Content> <Image Source="Images/i_about.png" Stretch="Fill" /> </Button.Content> <i:Interaction.Triggers> <i:EventTrigger EventName="MouseEnter"> <ei:ChangePropertyAction TargetName="myMenuItems" PropertyName="Visibility"> <ei:ChangePropertyAction.Value> <Visibility>Collapsed</Visibility> </ei:ChangePropertyAction.Value> </ei:ChangePropertyAction> </i:EventTrigger> <i:EventTrigger EventName="Click"> <actions:ToggleVisibilityAction TargetName="AboutWindow" /> </i:EventTrigger> </i:Interaction.Triggers> </Button> </StackPanel> </Canvas> </StackPanel> </Border> </userControls:CollapsiblePanel> <Image Source="Images/logo.png" HorizontalAlignment="Left" VerticalAlignment="Top" Stretch="Fill" Height="40" Width="40" Margin="-10" ToolTipService.ToolTip="Expand/Collapse Menu Bar"> <i:Interaction.Triggers> <i:EventTrigger EventName="MouseLeftButtonDown"> <actions:ToggleCollapseAction TargetName="MainManu" /> </i:EventTrigger> <i:EventTrigger EventName="MouseLeftButtonDown"> <ei:ChangePropertyAction TargetName="myMenuItems" PropertyName="Visibility"> <ei:ChangePropertyAction.Value> <Visibility>Collapsed</Visibility> </ei:ChangePropertyAction.Value> </ei:ChangePropertyAction> </i:EventTrigger> </i:Interaction.Triggers> </Image> </Grid>
<!-- The SubMenus --> <Grid x:Name="myMenuItems" HorizontalAlignment="Left" VerticalAlignment="Top" Margin="30,112"> <Border Style="{StaticResource CommonBorder}" Padding="10,3,10,3"> <StackPanel> <Button x:Name="myMenuItem1" Style="{StaticResource MenuItem}" ToolTipService.ToolTip="Your First Menu Here!" Content="LayerDef 1" Click="myMenuItem1_Click" /> <Button x:Name="myMenuItem2" Style="{StaticResource MenuItem}" ToolTipService.ToolTip="Your Second Menu Here!" Content="LayerDef 2" Click="myMenuItem2_Click" /> <Button x:Name="myMenuItem3" Style="{StaticResource MenuItem}" ToolTipService.ToolTip="Your Third Menu Here!" Content="Clear LayerDef" Click="myMenuItem3_Click" /> </StackPanel> </Border> <i:Interaction.Triggers> <i:EventTrigger EventName="MouseLeave"> <ei:ChangePropertyAction TargetName="myMenuItems" PropertyName="Visibility"> <ei:ChangePropertyAction.Value> <Visibility>Collapsed</Visibility> </ei:ChangePropertyAction.Value> </ei:ChangePropertyAction> </i:EventTrigger> <i:EventTrigger EventName="Loaded"> <ei:ChangePropertyAction TargetName="myMenuItems" PropertyName="Visibility"> <ei:ChangePropertyAction.Value> <Visibility>Collapsed</Visibility> </ei:ChangePropertyAction.Value> </ei:ChangePropertyAction> </i:EventTrigger> </i:Interaction.Triggers> </Grid> <!-- StackPanel containing the Base Map Switcher and the Application Toolbar --> <StackPanel Orientation="Horizontal" HorizontalAlignment="Right" Margin="0,5,5,0" VerticalAlignment="Top" > <!-- Base Map Switcher --> <Border x:Name="BaseMapSwitcher" Style="{StaticResource CommonBorder}" VerticalAlignment="Top" HorizontalAlignment="Right" Margin="5"> <StackPanel Orientation="Horizontal" Margin="5"> <RadioButton Content="Streets" IsChecked="True" ToolTipService.ToolTip="Worldwide Street Map" GroupName="BaseLayer" Margin="5,0,0,0" Foreground="White" FontSize="11" > <i:Interaction.Triggers> <i:EventTrigger EventName="Checked"> <actions:SetLayerUrlAction TargetName="Map" LayerID="BaseLayer" Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/> </i:EventTrigger> </i:Interaction.Triggers> </RadioButton> <RadioButton Content="Topo" GroupName="BaseLayer" ToolTipService.ToolTip="United States Topographic Map" Margin="5,0,0,0" Foreground="White" FontSize="11" > <i:Interaction.Triggers> <i:EventTrigger EventName="Checked"> <actions:SetLayerUrlAction TargetName="Map" LayerID="BaseLayer" Url="http://services.arcgisonline.com/ArcGIS/rest/services/USA_Topo_Maps/MapServer"/> </i:EventTrigger> </i:Interaction.Triggers> </RadioButton> <RadioButton Content="Imagery" ToolTipService.ToolTip="Worldwide Satellite Imagery Map" GroupName="BaseLayer" Margin="5,0,0,0" Foreground="White" FontSize="11" > <i:Interaction.Triggers> <i:EventTrigger EventName="Checked"> <actions:SetLayerUrlAction TargetName="Map" LayerID="BaseLayer" Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer"/> </i:EventTrigger> </i:Interaction.Triggers> </RadioButton> </StackPanel> </Border> <!-- Toolbar --> <Grid Margin="5"> <userControls:CollapsiblePanel x:Name="MainToolbar" IsExpanded="True" RenderTransformOrigin="1,0" VerticalContentAlignment="Stretch" HorizontalContentAlignment="Stretch" Margin="0,0,5,0"> <Grid HorizontalAlignment="Left" Effect="{StaticResource dropShadow}"> <Border Style="{StaticResource CommonBorder}" Margin="0,0,0,18" Effect="{x:Null}" /> <StackPanel Orientation="Horizontal" Margin="0,7,15,0"> <Button x:Name="btnToggleBaseMapSwitcher" Style="{StaticResource ToolbarButton}" ToolTipService.ToolTip="Toggle visibility of the base map switcher"> <Button.Content> <Image Source="Images/i_clickglobe.png" Stretch="Fill" /> </Button.Content> <i:Interaction.Triggers> <i:EventTrigger EventName="Click"> <actions:ToggleVisibilityAction TargetName="BaseMapSwitcher" /> </i:EventTrigger> </i:Interaction.Triggers> </Button> <Button x:Name="btnToggleOverviewMap" Style="{StaticResource ToolbarButton}" ToolTipService.ToolTip="Toggle visibility of the overview map"> <Button.Content> <Image Source="Images/i_overview.png" Stretch="Fill" /> </Button.Content> <i:Interaction.Triggers> <i:EventTrigger EventName="Click"> <actions:ToggleVisibilityAction TargetName="OverviewMapPanel" /> </i:EventTrigger> </i:Interaction.Triggers> </Button> <Button x:Name="btnToggleMagnifyingGlass" Style="{StaticResource ToolbarButton}" ToolTipService.ToolTip="Toggle visibility of the magnifying glass"> <Button.Content> <Image Source="Images/i_magnifyglass.png" Stretch="Fill" /> </Button.Content> <i:Interaction.Triggers> <i:EventTrigger EventName="Click"> <actions:ToggleVisibilityAction TargetName="MagnifyingGlass" /> </i:EventTrigger> </i:Interaction.Triggers> </Button> </StackPanel> </Grid> </userControls:CollapsiblePanel> <Image Source="Images/i_tools.png" HorizontalAlignment="Right" VerticalAlignment="Top" Stretch="Fill" Height="30" Width="30" Margin="-5" ToolTipService.ToolTip="Expand/Collapse Toolbar"> <i:Interaction.Triggers> <i:EventTrigger EventName="MouseLeftButtonDown"> <actions:ToggleCollapseAction TargetName="MainToolbar" /> </i:EventTrigger> </i:Interaction.Triggers> </Image> </Grid> </StackPanel> <!-- Navigator --> <esri:Navigation x:Name="Navigator" HorizontalAlignment="Left" VerticalAlignment="Bottom" Margin="40,0,0,30" Map="{Binding ElementName=Map}" /> <!-- Scale Bar --> <userControls:ScaleBar x:Name="ScaleBar" MapUnit="Meters" Map="{Binding ElementName=Map}" HorizontalAlignment="Left" VerticalAlignment="Bottom" Margin="20,0,0,10" />
<!-- Overview Map Window --> <userControls:WindowPanel x:Name="OverviewMapPanel" Width="212" Height="231" VerticalContentAlignment="Stretch" HorizontalContentAlignment="Stretch" HorizontalAlignment="Right" VerticalAlignment="Top" Margin="0,89,10,0"> <i:Interaction.Triggers> <i:EventTrigger EventName="Loaded"> <ei:ChangePropertyAction PropertyName="Visibility"> <ei:ChangePropertyAction.Value> <Visibility>Collapsed</Visibility> </ei:ChangePropertyAction.Value> </ei:ChangePropertyAction> </i:EventTrigger> </i:Interaction.Triggers> <esri:OverviewMap x:Name="OVMap" Margin="0" Map="{Binding ElementName=Map}"> <esri:OverviewMap.Layer> <esri:ArcGISTiledMapServiceLayer Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer" /> </esri:OverviewMap.Layer> </esri:OverviewMap> <userControls:WindowPanel.ContentTitle> <StackPanel Orientation="Horizontal"> <Image Source="Images/i_overview.png" HorizontalAlignment="Left" VerticalAlignment="Top" Stretch="Fill" Width="20" Height="20" Margin="5,2,0,0" /> <TextBlock Foreground="White" FontSize="12" Text="Overview Map" Width="100" TextWrapping="NoWrap" Height="Auto" HorizontalAlignment="Left" Margin="5,3,0,0" /> </StackPanel> </userControls:WindowPanel.ContentTitle> </userControls:WindowPanel> <!-- Magnifying Glass --> <esri:MagnifyingGlass x:Name="MagnifyingGlass" HorizontalAlignment="Left" VerticalAlignment="Top" Map="{Binding ElementName=Map}" Margin="50,150,0,0" Visibility="Collapsed"> <esri:MagnifyingGlass.Layer> <esri:ArcGISTiledMapServiceLayer Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer" /> </esri:MagnifyingGlass.Layer> </esri:MagnifyingGlass> <!-- About Window --> <userControls:WindowPanel x:Name="AboutWindow" Width="375" Height="150" Visibility="Collapsed" Effect="{StaticResource dropShadow}" Background="{StaticResource CommonBackgroundBrush}" VerticalContentAlignment="Stretch" HorizontalContentAlignment="Stretch"> <StackPanel Orientation="Vertical"> <TextBlock Style="{StaticResource Title}" TextWrapping="NoWrap" Text="{StaticResource ApplicationTitle}" Width="Auto" Height="Auto" Margin="5,3,0,0" /> <TextBlock Style="{StaticResource Subtitle}" TextWrapping="NoWrap" Text="{StaticResource ApplicationSubtitle}" Width="Auto" Height="Auto" Margin="5,1,0,0" /> <Line X1="5" Y1="50" X2="355" Y2="50" Stroke="White" StrokeThickness="0.25" /> <TextBlock Foreground="Yellow" FontSize="11" Width="Auto" TextWrapping="NoWrap" Text="{StaticResource ApplicationInfo}" Height="Auto" HorizontalAlignment="Left" Margin="5,3,0,0" /> </StackPanel> <userControls:WindowPanel.ContentTitle> <StackPanel Orientation="Horizontal"> <Image Source="Images/logo.png" HorizontalAlignment="Left" VerticalAlignment="Top" Stretch="Fill" Width="20" Height="20" Margin="5,2,0,0" /> <TextBlock Foreground="White" FontSize="12" Text="About" Width="100" TextWrapping="NoWrap" Height="Auto" HorizontalAlignment="Left" Margin="5,3,0,0" /> </StackPanel> </userControls:WindowPanel.ContentTitle> </userControls:WindowPanel> </Grid> </UserControl>
