open table...
3765
04-21-2015 05:15 AM
LucianaArrúa
Hello!
I tried the sample https://developers.arcgis.com/silverlight/sample-code/start.htm#FeatureDataGrid
But ,in the example linking to table is static .I want to open the table of attributes with menu contextual .
Please, any suggestions about this.
Thanks!
Luciana
Asgharkhan
The Easiest way i know you use mouse right button down event,then disable the default menu , and make your  own menu , then you bind menu item to attributes , i think this should work
May this Tutorial will help you Right Click and Context Menu in Silverlight 4
