IsInScaleRange not working in Legend
7937
11
05-07-2013 11:34 PM
AlekseyShulga
I found a weird bug. I use a simple example:
<esri:Map x:Name="MyMap"  WrapAround="True">
    <esri:ArcGISDynamicMapServiceLayer Url="http://myserver/arcgis/rest/services/objects/MapServer" />
</esri:Map>
<esri:Legend Map="{Binding ElementName=MyMap}" LayerItemsMode="Tree" ShowOnlyVisibleLayers="False" >
    <esri:Legend.MapLayerTemplate>
        <DataTemplate>
            <StackPanel Orientation="Horizontal">
                <CheckBox Content="{Binding Label}" IsChecked="{Binding IsEnabled, Mode=TwoWay}"
                                IsEnabled="{Binding IsInScaleRange}" >
                </CheckBox>
            </StackPanel>
        </DataTemplate>
    </esri:Legend.MapLayerTemplate>
    <esri:Legend.LayerTemplate>
        <DataTemplate>
            </CheckBox>
        </DataTemplate>
    </esri:Legend.LayerTemplate>
</esri:Legend>
It's ok. IsEnabled="{Binding IsInScaleRange}" works.
I add ArcGISTiledMapServiceLayer in the map before my ArcGISDynamicMapServiceLayer, I get:
- if ArcGISTiledMapServiceLayer is a tiled map service, IsInScaleRange works
- if ArcGISTiledMapServiceLayer is a image service, IsInScaleRange NOT works
<esri:ArcGISTiledMapServiceLayer ShowLegend="False" Url="http://myserver/arcgis/rest/services/base/MapServer" />
<esri:ArcGISTiledMapServiceLayer ShowLegend="False" Url="http://myserver/arcgis/rest/services/ortho/ImageServer" />
I don't want to use ArcGISImageServiceLayer for the ImageServer, because ArcGISImageServiceLayer displayed very slowly. Why is it not working?
PS: This example works fine on JavaScript, but not work on SL.
DominiqueBroux
Esri Frequent Contributor
Could you share the URL of the non working service?
Thanks
AlekseyShulga
Ok. But I need some time to prepare test services and publish them for you. My services now is private.
AlekseyShulga
DominiqueBroux
I eventually reproduced the issue.
We'll try to get it fixed in a future version.
Meanwhile, the workaround may be to set the Layer minimum and MaximumResolution accordinly with the min and max scale defined at server side.
Thanks for reporting that.
AlekseyShulga
Thanks.
When the expected release of a new version?
AlekseyShulga
Ver 3.2 nothing changed... 😞
DominiqueBroux
The issue is supposed to be fixed with version 3.2.
Do you mean that you still run into the issue after migrating to 3.2?
AlekseyShulga
Hi, dbroux.
After migration to 3.2 IsInScaleRange work fine for map-layers in WGS84, but if I use custom spatial reference this bug still exists. Now I'm experimenting to confirm this.
I'll tell the result later.
AlekseyShulga
Confirmation.
IsInScaleRange changing, if I use spatial reference WKID=102100 (wgs84 web mercator). For custom SR IsInScaleRange not work.
