private void AddMarker(UnitUI unit) { var graphic = new Graphic() { Symbol = GetSymbol(unit) }; double lat = unit.Base.Latitude; double lng = unit.Base.Longitude; var point = new MapPoint(lng, lat); point.SpatialReference = MyMap.SpatialReference; graphic.Geometry = new WebMercator().FromGeographic(point); <--error here "Invalid spatial reference " GraphicsLayer.Graphics.Add(graphic); }
<esri:Map WrapAround="True" x:Name="MyMap" Grid.Row="1" Grid.ColumnSpan="2"> <esri:ArcGISTiledMapServiceLayer Initialized="MyMapLayer_Initialized" Url="{StaticResource MapUrl}"/> <esri:GraphicsLayer Initialized="MyMapLayer_Initialized"> </esri:GraphicsLayer> <i:Interaction.Behaviors> <esri:MaintainExtentBehavior /> </i:Interaction.Behaviors> </esri:Map>
The second map doesnt work because it's defined as mercator spatial reference but you are treating it as if it were geographic.
Any idea what I need to change to fix it? Do I need to use something other than WebMercator for the 2nd map? And how would I know what mercator to use if I allow the user to switch between different maps?
var point = new MapPoint(lng, lat, new SpatialReference(4326)); if (MyMap.SpatialReference.WKID == 4326) // Geographic coordinates { graphic.Geometry = point; } else { graphic.Geometry = new WebMercator().FromGeographic(point); }
graphic.Geometry = new MapPoint(lng, lat, new SpatialReference(4326));
If your map is already using Geographical coordinates, you don't need any projection (assuming that your lng and lat are always geographical coordinates whatever the map SR)So, this should work: var point = new MapPoint(lng, lat, new SpatialReference(4326)); if (MyMap.SpatialReference.WKID == 4326) // Geographic coordinates { graphic.Geometry = point; } else { graphic.Geometry = new WebMercator().FromGeographic(point); } That being said, from 2.3, the graphics layer is able to autoproject the geometry.So this sould work as well:graphic.Geometry = new MapPoint(lng, lat, new SpatialReference(4326));
private void ZoomTo(double lat, double lng, int level) { var newResolution = GetResolution(level); double halfWidth = newResolution * MyMap.ActualWidth / 2; double halfHeight = newResolution * MyMap.ActualHeight / 2; var point = new MapPoint(lat, lng, new SpatialReference(4326)); Envelope newExtent = new Envelope(point.X - halfWidth, point.Y - halfHeight, point.X + halfWidth, point.Y + halfHeight); MyMap.Extent = newExtent; }
var point = new MapPoint(lat, lng, new SpatialReference(4326)); if (!point.SpatialReference.Equals(MyMap.Spatialreference)) point = new WebMercator().FromGeographic(point); // assuming your map is either in web mercator or in geographical coordinates. Might be more complex if you need to take all others cases into account Envelope newExtent = new Envelope(point.X - halfWidth, point.Y - halfHeight, point.X + halfWidth, point.Y + halfHeight); MyMap.Extent = newExtent;
Signed in members can post, follow updates, and more. New here? Register a free account.
