IdentityManager appending '&' character at the end of the URL
2416
03-26-2013 08:00 AM
MatejVrtich1
I am using IdentityManager to handle token authentication in my SL application.
The application is calling custom SOE thru ArcGISWebClient class, which ensures the authentication challenge on IdentityManager.
However, the IdentityManager seems to append '&' character at the end of the URL of the SOE call.
This causes the following error on the SOE:
{"error":{"code":500,"message":"An unexpected error occurred processing the request.","details":[]}}
You can test this on public ElevationsSOE:
Correct request: http://sampleserver4.arcgisonline.com/ArcGIS/rest/services/Elevation/ESRI_Elevation_World/MapServer/...
Incorrect request: http://sampleserver4.arcgisonline.com/ArcGIS/rest/services/Elevation/ESRI_Elevation_World/MapServer/...
Have you anybody encountered this issue?
Matej
DominiqueBroux
Esri Frequent Contributor
Thanks for reporting that issue, you'll try to get it fixed as soon as possible.
DominiqueBroux
