How to change TextSymbol color when its Graphic is selected?
785
10-25-2010 05:26 PM
ChenLi
I tried to follow the sample Graphics/Selections (http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#SelectGraphics) to make a TextSymbol, but the Graphic will show nothing with this TextSymbol. Please help:
<esri:TextSymbol x:Name="DefaultTextSymbol">
    <esri:TextSymbol.ControlTemplate>
        <ControlTemplate>
            <TextBlock x:Name="Element" FontFamily="Arial" FontSize="16" Foreground="Red" Text="ABC">
                <VisualStateManager.VisualStateGroups>
                    <VisualStateGroup x:Name="SelectionStates">
                        <VisualState x:Name="Normal">
                            <Storyboard>
                                <ColorAnimation Storyboard.TargetName="Element"
                                    Storyboard.TargetProperty="(TextBlock.Foreground).(SolidColorBrush.Color)"
                                    To="Red" Duration="00:00:00.25"/>
                            </Storyboard>
                        </VisualState>
                        <VisualState x:Name="Selected">
                            <Storyboard>
                                    To="Cyan" Duration="00:00:00.25"/>
                            </Storyboard>
                        </VisualState>
                    </VisualStateGroup>
                </VisualStateManager.VisualStateGroups>
            </TextBlock>
        </ControlTemplate>
    </esri:TextSymbol.ControlTemplate>
</esri:TextSymbol>
TextSymbol textSymbol = DefaultTextSymbol;
textSymbol.Text = "xyz;
graphic.Symbol = textSymbol;
MyGraphicsLayer.Graphics.Add(graphic);
DominiqueBroux
Esri Frequent Contributor
One issue is that you didn't bind the Textblock to Symbol.Text:
<TextBlock x:Name="Element" FontFamily="Arial" FontSize="16" Foreground="Red"  Text="{Binding Symbol.Text}">
That being said, it doesn't fully explain your issue because you shoud get a fixed string : "ABC".
Perhaps an issue with the geometry of your graphic. How did you initialize it?
ChenLi
After the machine reboot, the above XAML works. Don't know why.
Thank you, Dominique, the text graphic is added to a graphicLayer by Draw.DrawMode = DrawMode.Point.
Chen Li
