FeatureLayer SaveEdits error
1318
08-30-2011 09:26 AM
ThomasDobrzinski1
I try to add points to my FeatureLayer. Unfortunately the FeatureLayer doesn´t recognize the Edits and I don´t know why
foreach (var fl in OMap.Layers)
      if (fl is ESRI.ArcGIS.Client.FeatureLayer)
       if ((fl as ESRI.ArcGIS.Client.FeatureLayer).Url == "http://.../myFeatureLayer/FeatureServer/0")
        oFeatureLayer = fl as ESRI.ArcGIS.Client.FeatureLayer;
     ESRI.ArcGIS.Client.Geometry.MapPoint mp = new ESRI.ArcGIS.Client.Geometry.MapPoint(X, Y);
     Graphic graphic = new Graphic();
     graphic.Geometry = mp;
     graphic.Attributes.Add("guid", g);
     oFeatureLayer.Graphics.Add(graphic);
     if (oFeatureLayer.HasEdits)
     oFeatureLayer.SaveEdits();
What´s wrong with it? Do have have to initialize the FeatureLayer? Any ideas?
best regards and many thanks !
JenniferNery
Try to run fiddler and/or subscribe to SaveEditsFailed/EndSaveEdits events. There could be required attributes that you are not setting or attribute value type had a mismatch.
You can follow the same troubleshooting steps in this blog post: http://blogs.esri.com/Dev/blogs/silverlightwpf/archive/2009/08/24/Troubleshooting-blank-layers.aspx
wangzhifang
Always double check your graphic�??s attributes. If there is something wrong, such as format doesn't match on serverside, SaveEdits() will do nothing.
ThomasDobrzinski1
thank you for your replies.
The error is:
When adding the attribute "guid" to the feature the error occurs.
"guid" is an esri guid field, the g was created with
System.Guid g;
g = (Guid.NewGuid());
Are there any special features that can go wrong?
The add of a feature without giving the attributes works fine.
Thanks again !
best regards
SOLVED:
It was an error with the guid, the "{", "}" were needed...
