ESRI Layer Extent Fails When you Rotate
1660
06-12-2014 02:31 PM
JordanParfitt
I'm somewhat new to the silverlight api. When I rotate my map 45 degrees all the layers get cut off because the extent has changed. It only shows half the layer. The part that rotated off the screen is probably showing too, but the new visible map doesn't have my ooverlays on it.
Is this a bug? Is there a work around? I can't rotate the layer itself can I?
Thank you in advance.
JordanParfitt
I tried to upload pictures of what I'm talking about..
Here is before rotation:
[ATTACH=CONFIG]34664[/ATTACH]
Here is after:
[ATTACH=CONFIG]34666[/ATTACH]
