Displaying polygons as points in a feature layer
2349
03-05-2013 08:07 PM
NANA
Hello,
We want to display a polygon layer as points feature layer (with a marker symbol I guess) so there's a big enough target for a map tip in any map scale, because some of the polygons are quite small.
The option of duplicating the layer as a points layer in SDE obviously isn't optimal.
We're using ArcGIS server 10 but if there's a better solution for 10.1 I'd like to know as well.
Do you have other ideas?
Thanks
DominiqueBroux
Esri Frequent Contributor
One option is that you create a point layer at client side from the polygon geometries.
This Pie Chart sample is doing that. You can look at CentroidHelper class. For each polygon a point is created, the point position is either the center of the polygon if this one is inside the polygon else a geometry service is used to get a better position.
DominiqueBroux
NANA
Nice solution, thanks.
