Display query results on map
1986
6
04-29-2010 10:31 AM
AnilDhiman
I have a scenario where, few feature layers in geodatabase(SQL server)  are related to some tables through ARCSDE. I have created relationship classes with these tables in arccatalog.
Now when my Silverlight map loads, I need to pass some other table Primary key and display the geometry from feature layer table linked to this primary key.
Feature Layer F, --- OBJECTID, SHAPE
Relation Table R, -- ID,OID,RID,NAME
Table A ------------- RID,CITY
I have to pass RID which will again retrieve gemetries related to this RID and display on map. Can anyone please suggest few pointers to achieve this functionality.
AnilDhiman
This forum is bit slow in replying.. I am still stuck with this issue.
dotMorten_esri
Esri Notable Contributor
The REST service in ArcGIS Server 9.3.* does not supported related fields. You will need to wait for the final release of ArcGIS Server 10.0 and v2.0 of the Silverlight API for this support.
NikkiGolding
I just downloaded the SL API 2.0 Beta  and cannot figure out where in the SL API related records are accesible.
I can see the supported operation 'query related records' via the REST API on the service, but I am unable to determine what in the SL API will faciliate a query to related records.  I am sure there is something obvious .. that  I missing.
dotMorten_esri
Unfortunately this didn't make it for the beta cut, but will be available in the next release.
BrianGustafson
Are there any samples for querying related records?
dotMorten_esri
I believe this is the method you are looking for: http://help.arcgis.com/en/webapi/silverlight/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.Tasks.Quer...
It works pretty much the same way as a "normal" query.
