Can I convert decimal degrees to Sq Km on client side ?
7761
05-13-2010 06:56 AM
praveentadikemalla
  Can I convert decimal degrees to Sq Km on client side only or should I create a geoprocessing service to do that?
If I can convert it on client side, please let me how I can do it and what all would be my requirements. I have gone through many sites but didn't find any relevant data. Please help me out
Thanks and Regards
T. Praveen.
DominiqueBroux
Esri Frequent Contributor
The extension method 'ESRI.ArcGIS.Client.Bing.Transform.GeographicToWebMercator(this ESRI.ArcGIS.Client.Geometry.MapPoint)' should be helpful.
/Dominique
dotMorten_esri
Esri Notable Contributor
You probably don't want to calculate distance and area in WebMercator. The distortions are way too large to be of any use.
Instead I suggest you look at some of the basic formulas for working with spheric coordinates. I usually use this resource for that: http://williams.best.vwh.net/avform.htm
Just as a side note: Decimal degrees is a measure of angle. Square Kilometers is measure of area. Those are two very different things, and doesn't "convert". I'm guessing you mean you have a polygon described by points in decimal degrees, and you would like to know the area of the polygon, right?
