"Failed to get the legend info of layer..."
669
02-28-2012 05:55 PM
BrianMoran1
Hello all,
I'm a novice web application developer, and I have been playing around with the configurable template provided in one of ESRI's code samples:
http://www.arcgis.com/home/item.html?id=ad9b257016ab40ee9def89ac2d3db2b3
I've had my fair share of hiccups while playing around with this template, but I've had one I cant seem to solve.  I am attempting to add a layer (map service) from my server which I run on my personal machine onto the application.  This is the syntax I am using
<Layer title="Nuclear Power Plants" serviceType="Dynamic" opacityBar="false" opacity="1.0" visibleInitial="true" toggleLayer="false" visibleLayers="*" refreshRate="0" restURL="http://brian-thinkpad/MoranGISServer/services/power_plants/MapServer" proxyURL="" token=""></Layer>
I feel like it should be working, however when I deploy the application, I get this error message:
[ATTACH=CONFIG]12299[/ATTACH]
followed by another message that the layer has failed to initialize.
Can anyone help me get to the root of this issue?
Thanks a lot!
BrianMoran1
Any help/guidance would be greatly appreciated!
DominiqueBroux
Esri Frequent Contributor
Your question seems very tied to that sample posted on arcgis.com gallery.
You could try to pst your question there.
