Using a variable to get the pageRow field value in a Map Series?
1519
12-16-2020 10:12 AM
ArwenVaughan1
In the snippet below you can see that I am calling  ms.pageRow.PageName to get the value for the field named "PageName" in my Index Layer. This is how all the sample code I have found does it. But, how can you do this using a string variable for the field name? For instance you want to pass in the field name as an argument to the script. I have tried getValue("PageName") like you see in the SDK documentation, but that does not work. Any ideas?
if not lyt.mapSeries is None:
  ms = lyt.mapSeries
if ms.enabled:
  for pageNum in range(1, ms.pageCount + 1):
    ms.currentPageNumber = pageNum
    page = ms.pageRow.PageName # <-- ??How to use a variable field name here??
    print(" - {0}".format(output_path + f"file_{page}.pdf"))
    lyt.exportToPDF(output_path + f"file{page}.pdf", resolution = 300)
RianCrowley1
Unfortunately, the ESRI docs are wrong.  MapSeries.pageRow doesn't return a Row object, but a pageRow object, which does not have the getValue method.
You can use Python's getattr method to return the value instead.
page = getattr(ms.pageRow, ms.pageNameField.name)
FranziskaSumpf
How is this still wrong in the docs in 2026?
Anyway, if your index layer has a join and you have to use qualified field names (e.g. joinTable.FieldName), you have to replace the . with _
ms.pageNameField.name won't work, either (but you could probably use replace to replace the dot).
page = getattr(ms.pageRow, 'joinTable_FieldName')
