The version of the binaries in the active Python environment do not match the version of the binaries of the ArcGIS Pro application. Active environ
4830
02-17-2021 08:05 PM
by Anonymous User
Not applicable
Hi all,
Anyone encountered this before..
when I try to import the arcgis.gis getting error below, i guess this probably because i've applied the patch for the pro.
Active environment version : 2.5
arcgispro-py3 environment version : 2.6
Tags (1)
DanPatterson
MVP Esteemed Contributor
I am guessing that you have a clone as well as the arcgis pro environment?
If so, you have to activate the correct environment, or just do what I do... don't clone and install what you need in the base C:\YourInstallFolder\bin\Python\envs\arcgispro-py3 folder.
I wouldn't recommend doing that if you are using any of the "deep" stuff, too many dependencies (issues)
... sort of retired...
by Anonymous User
Not applicable
thanks Dan. Yes.. I did clone the pro environment for developing purpose trying to avoid potential problems to ArcGIS Pro..
I
DanPatterson
make sure you switch into it either using conda, or fire up Pro and change it there (then close Pro)
