Hello,
I have many feature service in my portal which contains 4 to 6 layers in each of them, I wanted to list all the feature service which contain a specific layer called WETTBEWER which is layer (0) in all the feature services. I have the following code, but nothing is returned in the results, What Am I doing wrong ?? The specific process is done in the json_writer.py.
**config.json**
"url": "https://url/portal/",
"username": "user",
"password":"pass",
"query": "title: WETTBEWER",
"item_type": "Feature Service",
"max_items": 400
**json_reader.py**
import json
class JsonReader:
def __init__(self, filename):
self.filename = filename
def read_json_file(self):
with open(self.filename) as file:
data = json.load(file)
return data
def get_config(self, config):
loaded_json = self.read_json_file()
config = loaded_json[config]
return config
**portal_connection.py**
from arcgis.gis import GIS
class PortalConnection:
def __init__(self, url, username, password):
self.url = url
self.username = username
self.password = password
def connect(self, query, layer, max_items):
# Connection to ArcGIS Enterprise using a built-in account
print("Portal for ArcGIS as a built in user")
gis_portal = GIS(self.url, self.username, self.password)
print("Logged in as: " + gis_portal.properties.user.username)
return gis_portal, query, layer, max_items
**Esri_api.py**
class EsriApi:
def __init__(self, portal, item_type, query, max_items):
self.item_type = item_type
self.query_ = query
self.portal = portal
self.max_items = max_items
def query(self):
api_query_result = self.portal.content.search(query=self.query_, item_type=self.item_type, max_items=self.max_items)
return api_query_result
**json_writer.py**
class JsonWriter:
def __init__(self,api_query_result):
self.api_query_result = api_query_result
def printResults(self):
for item in self.api_query_result:
layers = item.layers
for lyr in layers:
try:
print(item.id, item.url, lyr.properties["id"], lyr.properties["name"])
except Exception as e:
print(e)
**Main.py**
from json_reader import JsonReader
from portal_connection import PortalConnection
from esri_api import EsriApi
from json_writer import JsonWriter
jreader = JsonReader('config.json')
url = jreader.get_config("url")
username = jreader.get_config("username")
password = jreader.get_config("password")
query = jreader.get_config("query")
layer = jreader.get_config("item_type")
max_items = jreader.get_config("max_items")
con = PortalConnection(url, username, password)
portal, query, layer, max_items = con.connect(query, layer, max_items)
esri_api = EsriApi(portal, layer, query, max_items)
results = esri_api.query()
jsonWriter = JsonWriter(results)
jsonWriter.printResults()
Thank you for the insights...
