I've cloned my environment in ArcGIS Pro setting and installed a bunch of stuff. When I open up Jupyter Notebooks, it still reverts back to the root environment.
Anyone know how to switch it for use in notebooks?
The easiest way to start Jupyter Notebook with your desired environment and from your desired startup location is to:
You can list the python environments available to switch to with: conda env list
See the screenshot below:
Some references on the web... the desktop shortcut route works
3. Running the Jupyter Notebook — Jupyter/IPython Notebook Quick Start Guide 0.1 documentation
but watch the time that the suggestions were made... the 'correct' approach is a moving solution
path - How to change the Jupyter start-up folder - Stack Overflow
If you have clones, make sure you have the proper environment activated.
Jupyter Lab is an option as well
JupyterLab Documentation — JupyterLab 2.0.0a0 documentation
shortcuts creation for Pro... not specific to notebook
/blogs/dan_patterson/2017/07/01/arcgis-pro-2-creating-desktop-shortcuts
Thanks Kimberley, this worked for me. I also had to install ipykernal in the new environment but now it's working.
Signed in members can post, follow updates, and more. New here? Register a free account.
